Vista - (VSS)Volume Shadow copy
Old 06-29-2008   #1 (permalink)
Howard Huntley
Using Symantec Backup Exec v11b, I am doing a tape remote tape backup
of my HP dv9000 notebook that is running Vista Home Premium 32 SP1
edition. The backup got near the end and failed with a (VCC) error
message. I am having to use the wireless connection because there is a
problem in the wired LAN card. What changes can I make to successfully
complete this back up of the C:\ and D:\ drive on the note book with
out this failure.
problems with volume shadow copy service Vista performance & maintenance
Volume Shadow Copy - Can it be turned off Vista performance & maintenance
VSS (Volume Shadow Copy Service) Vista General
Volume shadow copy Vista General
How do you stop Volume Shadow copy Vista General
