| | Sound Problem I can play music, and movies and even games but windows sounds are silent. Mute is off, volume is up. Any ideas? Thanks |
| | Re: Sound Problem On Sun, 29 Jun 2008 20:46:00 -0500, "Jackal" <jackal_m28@xxxxxx> wrote: Quote: Quote: >> "Jackal" <jackal_m28@xxxxxx> wrote in message >> news:40BDB00D-1D58-4DBD-A2E0-C619DF043B51@xxxxxx Quote: >>>I can play music, and movies and even games but windows sounds are silent. >>>Mute is off, volume is up. >>> >>> Any ideas? >>> >>> Thanks -- more pix @ http://members.toast.net/cbminfo/index.html |
| | Re: Sound Problem Why would I need to see what the sound scheme says? I already said that it was not set to "no sound". I can play music, and movies and even games but windows sounds are silent. Mute is off, volume is up. It is not set to "no sound". I'm running vista with all updates. Sound card has all updates. This is a laptop so there are no speakers attached to check on. Any ideas? <keepout@xxxxxx> wrote in message news:1nfg64pu16cvcdqv03803sjnfaa4nm2jtd@xxxxxx Quote: > On Sun, 29 Jun 2008 20:46:00 -0500, "Jackal" <jackal_m28@xxxxxx> > wrote: Quote: Quote: >>> "Jackal" <jackal_m28@xxxxxx> wrote in message >>> news:40BDB00D-1D58-4DBD-A2E0-C619DF043B51@xxxxxx >>>>I can play music, and movies and even games but windows sounds are >>>>silent. >>>>Mute is off, volume is up. >>>> >>>> Any ideas? >>>> >>>> Thanks >>> > see what the sound scheme says. > -- > more pix @ http://members.toast.net/cbminfo/index.html |
| | Re: Sound Problem Hi.. check that "wave" is on to and its not zero . Have you updatet the driver? Not from Vista update, but from you computer webpage? Greetz "Jackal" <jackal_m28@xxxxxx> wrote in message news:40BDB00D-1D58-4DBD-A2E0-C619DF043B51@xxxxxx Quote: >I can play music, and movies and even games but windows sounds are silent. >Mute is off, volume is up. > > Any ideas? > > Thanks |
| | Re: Sound Problem "Jackal" <jackal_m28@xxxxxx>'s wild thoughts were released on Sun, 29 Jun 2008 17:54:43 -0500 bearing the following fruit: Quote: >I can play music, and movies and even games but windows sounds are silent. >Mute is off, volume is up. > >Any ideas? screen. Click on 'mixer' Check the 'windows sounds' settings -- Jan Hyde https://mvp.support.microsoft.com/profile/Jan.Hyde |
| | #6 (permalink) |
| | Re: Sound Problem On Sun, 29 Jun 2008 21:15:41 -0500, "Jackal" <jackal_m28@xxxxxx> wrote: Quote: >Why would I need to see what the sound scheme says? I already said that it >was not set to "no sound". You have to RULE out what LOOKS like it's set right. Relying on memory to troubleshoot a problem, is a sure way to wind up checking the same thing over and over again, until you have it written down, with a check mark when you've checked it. Here's a huge list of things to check below. Step thru them THOROUGHLY. The sound scheme has many different settings. 1 There is the 'no sound scheme' 2 There is the 'windows sound scheme' And then under each option, there are individual sounds. They are WAV files. There's a little arrow to the right of each entry that 'IS DEFINED'. Scroll down 'find default beep' see if it has something defined. Then test it. If it works, test all those defined. You may have deleted the actual files. Quote: >I can play music, and movies and even games but windows sounds are silent. >Mute is off, volume is up. It is not set to "no sound". I'm running vista >with all updates. Sound card has all updates. This is a laptop so there are >no speakers attached to check on. create sound thru plastic. There's obviously nothing wrong with the speaker you're using. Are you sure it's ALL windows sounds ? I have maybe 3 that I hear regularly, the boot sound in my CUSTOM sound scheme, the default beep, and the LOGOFF sound. Other than that the sounds are pretty much silent. IOW: Who cares about a windows sound scheme ? The catastrophic failure sound will probably fail in the catastrophic smoke escaping from the computer case anyway's. I've seen the beeps on my email program disappear with EXTREME multitasking. try the default beep ie: stick it on a function key to test the sound. IOW: Make sure the PATH to the sounds still exists. Take and stick that CPU usage toy in the sidebar, and see if it isn't pegged out at the max. I have an orange speaker icon to realtek HD audio manager in the tray. right click and open yours if it's there. This one here [for me] has many 'DEFAULT' devices, I have check marks on line in and speakers. See if you haven't checked something else. Then uncheck it. Also see if any of the speakers on any of these are red xed out. Windows if nothing else has many off switches for the SAME damn thing. And there's always a chance to miss one of those off switches. But Windows doesn't miss them, it just doesn't tell you where they are or what the Systems status is. speaking of. Did you use '%SystemRoot%\system32\compmgmt.msc /s' in the RUN box, and see if any of the devices are flagged ? while you're in the tray see if you have a white speaker with blue sound waves coming out. volume mixer. Open it and see if anything is muted.. Quote: > Any ideas? toggled in sound manager. Also sound scheme fiddled with. All of which has happened on my machine. Quote: ><keepout@xxxxxx> wrote in message >news:1nfg64pu16cvcdqv03803sjnfaa4nm2jtd@xxxxxx Quote: >> On Sun, 29 Jun 2008 20:46:00 -0500, "Jackal" <jackal_m28@xxxxxx> >> wrote: Quote: >>>> "Jackal" <jackal_m28@xxxxxx> wrote in message >>>> news:40BDB00D-1D58-4DBD-A2E0-C619DF043B51@xxxxxx >>>>>I can play music, and movies and even games but windows sounds are >>>>>silent. >>>>>Mute is off, volume is up. >>>>> >>>>> Any ideas? >>>>> >>>>> Thanks >>>> >> see what the sound scheme says. >> -- >> more pix @ http://members.toast.net/cbminfo/index.html more pix @ http://members.toast.net/cbminfo/index.html |
| | #7 (permalink) |
| | Re: Sound Problem Like I said, it's all set up correctly. I've ruled out everything. That is why I come here in hopes of some advanced knowledge. <keepout@xxxxxx> wrote in message news:tmqh649qruh2chcfel7u4oq4b070uu3qt9@xxxxxx Quote: > On Sun, 29 Jun 2008 21:15:41 -0500, "Jackal" <jackal_m28@xxxxxx> > wrote: > Quote: >>Why would I need to see what the sound scheme says? I already said that it >>was not set to "no sound". > > You have to RULE out what LOOKS like it's set right. Relying on memory to > troubleshoot a problem, is a sure way to wind up checking the same thing > over > and over again, until you have it written down, with a check mark when > you've > checked it. > Here's a huge list of things to check below. Step thru them THOROUGHLY. > > The sound scheme has many different settings. > 1 There is the 'no sound scheme' > 2 There is the 'windows sound scheme' > > And then under each option, there are individual sounds. They are WAV > files. > There's a little arrow to the right of each entry that 'IS DEFINED'. > Scroll > down 'find default beep' see if it has something defined. Then test it. > If it > works, test all those defined. You may have deleted the actual files. > Quote: >>I can play music, and movies and even games but windows sounds are silent. >>Mute is off, volume is up. It is not set to "no sound". I'm running vista >>with all updates. Sound card has all updates. This is a laptop so there >>are >>no speakers attached to check on. > create sound thru plastic. There's obviously nothing wrong with the > speaker > you're using. > Are you sure it's ALL windows sounds ? I have maybe 3 that I hear > regularly, > the boot sound in my CUSTOM sound scheme, the default beep, and the LOGOFF > sound. > Other than that the sounds are pretty much silent. > IOW: Who cares about a windows sound scheme ? The catastrophic failure > sound > will probably fail in the catastrophic smoke escaping from the computer > case > anyway's. > > I've seen the beeps on my email program disappear with EXTREME > multitasking. > try the default beep ie: stick it on a function key to test the sound. > IOW: > Make sure the PATH to the sounds still exists. > > Take and stick that CPU usage toy in the sidebar, and see if it isn't > pegged > out at the max. > > I have an orange speaker icon to realtek HD audio manager in the tray. > right > click and open yours if it's there. > This one here [for me] has many 'DEFAULT' devices, I have check marks on > line > in and speakers. > See if you haven't checked something else. Then uncheck it. Also see if > any of > the speakers on any of these are red xed out. > Windows if nothing else has many off switches for the SAME damn thing. And > there's always a chance to miss one of those off switches. But Windows > doesn't > miss them, it just doesn't tell you where they are or what the Systems > status > is. > speaking of. Did you use '%SystemRoot%\system32\compmgmt.msc /s' in the > RUN > box, and see if any of the devices are flagged ? > > while you're in the tray see if you have a white speaker with blue sound > waves > coming out. volume mixer. Open it and see if anything is muted.. > Quote: >> Any ideas? > toggled in sound manager. > Also sound scheme fiddled with. All of which has happened on my machine. > > Quote: >><keepout@xxxxxx> wrote in message >>news:1nfg64pu16cvcdqv03803sjnfaa4nm2jtd@xxxxxx Quote: >>> On Sun, 29 Jun 2008 20:46:00 -0500, "Jackal" <jackal_m28@xxxxxx> >>> wrote: >>>>> "Jackal" <jackal_m28@xxxxxx> wrote in message >>>>> news:40BDB00D-1D58-4DBD-A2E0-C619DF043B51@xxxxxx >>>>>>I can play music, and movies and even games but windows sounds are >>>>>>silent. >>>>>>Mute is off, volume is up. >>>>>> >>>>>> Any ideas? >>>>>> >>>>>> Thanks >>>>> >>> >>> see what the sound scheme says. >>> -- >>> more pix @ http://members.toast.net/cbminfo/index.html > more pix @ http://members.toast.net/cbminfo/index.html |
| | #8 (permalink) |
| | Re: Sound Problem On Mon, 30 Jun 2008 11:20:29 -0500, "Jackal" <jackal_m28@xxxxxx> wrote: Quote: >Like I said, it's all set up correctly. I've ruled out everything. That is >why I come here in hopes of some advanced knowledge. FWIW: I just fixed my OnAir TV, on the 2nd account standard user, that wasn't loading, by turning off the self boot option for control panel, and the HP advisor, and turning the 'precision' option in the mouse off. Has NOTHING that I know of on booting the TV, but after a week of it not working, those 3 things, 1 of them fixed it. IOW: Make your check list, and check off when you physically check the item. It could be anything that's causing the sound to NOT work. Again How much multitasking is going on when the sounds fail ? Windows sounds NEED memory. My sounds failed with heavy usage. A reboot, and low usage, restored the sounds. Quote: > ><keepout@xxxxxx> wrote in message >news:tmqh649qruh2chcfel7u4oq4b070uu3qt9@xxxxxx Quote: >> On Sun, 29 Jun 2008 21:15:41 -0500, "Jackal" <jackal_m28@xxxxxx> >> wrote: >> Quote: >>>Why would I need to see what the sound scheme says? I already said that it >>>was not set to "no sound". >> >> You have to RULE out what LOOKS like it's set right. Relying on memoryto >> troubleshoot a problem, is a sure way to wind up checking the same thing >> over >> and over again, until you have it written down, with a check mark when >> you've >> checked it. >> Here's a huge list of things to check below. Step thru them THOROUGHLY. >> >> The sound scheme has many different settings. >> 1 There is the 'no sound scheme' >> 2 There is the 'windows sound scheme' >> >> And then under each option, there are individual sounds. They are WAV >> files. >> There's a little arrow to the right of each entry that 'IS DEFINED'. >> Scroll >> down 'find default beep' see if it has something defined. Then test it. >> If it >> works, test all those defined. You may have deleted the actual files. >> Quote: >>>I can play music, and movies and even games but windows sounds are silent. >>>Mute is off, volume is up. It is not set to "no sound". I'm running vista >>>with all updates. Sound card has all updates. This is a laptop so there >>>are >>>no speakers attached to check on. >> create sound thru plastic. There's obviously nothing wrong with the >> speaker >> you're using. >> Are you sure it's ALL windows sounds ? I have maybe 3 that I hear >> regularly, >> the boot sound in my CUSTOM sound scheme, the default beep, and the LOGOFF >> sound. >> Other than that the sounds are pretty much silent. >> IOW: Who cares about a windows sound scheme ? The catastrophic failure >> sound >> will probably fail in the catastrophic smoke escaping from the computer >> case >> anyway's. >> >> I've seen the beeps on my email program disappear with EXTREME >> multitasking. >> try the default beep ie: stick it on a function key to test the sound. >> IOW: >> Make sure the PATH to the sounds still exists. >> >> Take and stick that CPU usage toy in the sidebar, and see if it isn't >> pegged >> out at the max. >> >> I have an orange speaker icon to realtek HD audio manager in the tray. >> right >> click and open yours if it's there. >> This one here [for me] has many 'DEFAULT' devices, I have check marks on >> line >> in and speakers. >> See if you haven't checked something else. Then uncheck it. Also see if >> any of >> the speakers on any of these are red xed out. >> Windows if nothing else has many off switches for the SAME damn thing.And >> there's always a chance to miss one of those off switches. But Windows >> doesn't >> miss them, it just doesn't tell you where they are or what the Systems >> status >> is. >> speaking of. Did you use '%SystemRoot%\system32\compmgmt.msc /s' in the >> RUN >> box, and see if any of the devices are flagged ? >> >> while you're in the tray see if you have a white speaker with blue sound >> waves >> coming out. volume mixer. Open it and see if anything is muted.. >> Quote: >>> Any ideas? >> toggled in sound manager. >> Also sound scheme fiddled with. All of which has happened on my machine. >> >> Quote: >>><keepout@xxxxxx> wrote in message >>>news:1nfg64pu16cvcdqv03803sjnfaa4nm2jtd@xxxxxx >>>> On Sun, 29 Jun 2008 20:46:00 -0500, "Jackal" <jackal_m28@xxxxxx> >>>> wrote: >>>>>> "Jackal" <jackal_m28@xxxxxx> wrote in message >>>>>> news:40BDB00D-1D58-4DBD-A2E0-C619DF043B51@xxxxxx >>>>>>>I can play music, and movies and even games but windows sounds are >>>>>>>silent. >>>>>>>Mute is off, volume is up. >>>>>>> >>>>>>> Any ideas? >>>>>>> >>>>>>> Thanks >>>>>> >>>> >>>> see what the sound scheme says. >>>> -- >>>> more pix @ http://members.toast.net/cbminfo/index.html >> more pix @ http://members.toast.net/cbminfo/index.html more pix @ http://members.toast.net/cbminfo/index.html |
| | #9 (permalink) |
| | Re: Sound Problem Can you play your windows sound files from their folder through a media player? DH "Jan Hyde (VB MVP)" <StellaDrinker@xxxxxx> wrote in message news koh6452upbrst4h4v06jvivs1lftaob3d@xxxxxxQuote: > "Jackal" <jackal_m28@xxxxxx>'s wild thoughts were > released on Sun, 29 Jun 2008 17:54:43 -0500 bearing the > following fruit: > Quote: >>I can play music, and movies and even games but windows sounds are silent. >>Mute is off, volume is up. >> >>Any ideas? > Click on the speaker icon in the botton right of your > screen. > > Click on 'mixer' > > Check the 'windows sounds' settings > > > > > -- > Jan Hyde > > https://mvp.support.microsoft.com/profile/Jan.Hyde |
| | #10 (permalink) |
| | Re: Sound Problem Yes they will play. I click on them and they open up the media player and do their thing. This is puzzling. "DecHex" <725012b1014@xxxxxx> wrote in message news:38B9534C-9C5F-4E6C-B0A2-171719682913@xxxxxx Quote: > Can you play your windows sound files from their folder through a media > player? > DH > > "Jan Hyde (VB MVP)" <StellaDrinker@xxxxxx> wrote in message > news koh6452upbrst4h4v06jvivs1lftaob3d@xxxxxxQuote: >> "Jackal" <jackal_m28@xxxxxx>'s wild thoughts were >> released on Sun, 29 Jun 2008 17:54:43 -0500 bearing the >> following fruit: >> Quote: >>>I can play music, and movies and even games but windows sounds are >>>silent. >>>Mute is off, volume is up. >>> >>>Any ideas? >> Click on the speaker icon in the botton right of your >> screen. >> >> Click on 'mixer' >> >> Check the 'windows sounds' settings >> >> >> >> >> -- >> Jan Hyde >> >> https://mvp.support.microsoft.com/profile/Jan.Hyde |
| sound problem | Sound & Audio | |||
| Problem with sound | Vista hardware & devices | |||
| Sound problem | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| 5.1 sound problem with Realtek ACL655 on board sound | Vista hardware & devices | |||
