| | Attention Vista Freezes Problem Solved! After several weeks trying to solve this problem, even reformatting, replacing the power supply, cables, memory sticks, and more, I believe I found the origin of the problem. And it seems to be related to Vista. Go to > Settings > Control Panel > Power Options > check the "High Performance" option and then click the blue line underneath that reads: "Change Plan Settings" a new windows will appear, click the blue line that reads: "Change Advanced Power Settings", the "Power Options Advance Settings" appear and you should click the "+" mark on "Hard Disk", then click on "Turn off hard disk after", and set to "Never". My several HD are all SATA, and when Vista shuts them down automatically, the SATA do not restart immediately, and this is seen as a temporary freeze. Since I entered these new settings, it's been working fine for a few days now. Good Luck Willy |
| | RE: Attention Vista Freezes Problem Solved! Not sure what the question was, but this was the answer for my formerly insomniac Dell-running-Vista machine. Amazing! Whodathunk? -- Joaneee "Willy" wrote: Quote: > After several weeks trying to solve this problem, even reformatting, > > replacing the power supply, cables, memory sticks, and more, > > I believe I found the origin of the problem. And it seems to be related > > to Vista. > > > > Go to > Settings > Control Panel > Power Options > check the "High > > Performance" option and then click the blue line underneath that reads: > > "Change Plan Settings" a new windows will appear, click the blue line > > that reads: "Change Advanced Power Settings", the "Power Options > > Advance Settings" appear and you should click the "+" mark on > > "Hard Disk", then click on "Turn off hard disk after", and set to "Never". > > > > My several HD are all SATA, and when Vista shuts them down automatically, > > the SATA do not restart immediately, and this is seen as a temporary freeze. > > > > Since I entered these new settings, it's been working fine for a few days > now. > > > > Good Luck > > Willy > > > |
| Vista not sleeping problem---SOLVED | Vista General | |||
| Solved my Vista/XP shared printer problem | Vista print fax & scan | |||
| VISTA PROBLEM SOLVED>>>>>MUST READ!!! | Vista installation & setup | |||
