| | Again: MS Mouse Pointer Speed Control - but WIN XP Prof. Hello all, original thread: http://groups.google.de/group/micros...20976ca3ad0b49 I have exactly the same nasty problem with my WIN XP prof. - since months. As mentioned above I tried to compare the Registry with incorrect and correct mouse pointer speed values. The correct value is [HKEY_CURRENT_USER\Control Panel\Mouse] "MouseSensitivity"="18" and [HKEY_USERS\S-1-5-21-...\Control Panel\Mouse] "MouseSensitivity"="18" I created two *.reg-files with these lines and tried to apply them after starting my PC. No success. I really must change the setting manually. Any hints? And why are my settings not saved? Is there any tool available for logging what is changed in the Registry and from which app/driver? Thanks so far and greetings Udo |
| | RE: Again: MS Mouse Pointer Speed Control - but WIN XP Prof. -- Udo; The following fix should work. Open "msconfig" and disable any third party mouse software ie: Logitech KHALMNPR. I understand you may need to do this twice in some cases, but it worked for me the first time. Ted B. "Udo" wrote: Quote: > Hello all, > > original thread: > http://groups.google.de/group/micros...20976ca3ad0b49 > > I have exactly the same nasty problem with my WIN XP prof. - since > months. > As mentioned above I tried to compare the Registry with incorrect and > correct > mouse pointer speed values. The correct value is > > [HKEY_CURRENT_USER\Control Panel\Mouse] > "MouseSensitivity"="18" > > and > > [HKEY_USERS\S-1-5-21-...\Control Panel\Mouse] > "MouseSensitivity"="18" > > I created two *.reg-files with these lines and tried to apply them > after starting my PC. No success. I really must change the setting > manually. Any hints? And why are my settings not saved? Is there > any tool available for logging what is changed in the Registry > and from which app/driver? > > > Thanks so far and greetings > Udo > |
| Mouse DPI and pointer speed at the Mouse Properties. | Vista General | |||
| How to increase mouse pointer speed past windows vista max | Vista hardware & devices | |||
| MS Mouse Pointer Speed Control | Vista General | |||
| Pointer speed | Vista hardware & devices | |||
| Pointer speed | Vista General | |||
