| | Problem with realtek on-board sound I have just installed RC1 and everything works great, except my sound. I have never had a problem out of it, even with the Beta 2, but with the new RC1 I cannot get 5.1 to work. Iv tried the auto-update that came with RC1 and it would not allow me to open or setup my speaker configuration in any way through Realtek's suplied menus and options, but I can go through the Playback Devices option and still set things to 5.1. But Even setting that to 5.1, it still will not play any sound through my back left or right speaker. I uninstalled the driver, then installed the driver from Realtek's website for Vista, and still I have no working Realtek menus, and Im still limited to 2.1. Upon attempting to open the Realtek icon in the tray or control panel, it brings up an error saying "HD Audio Control Panel for Vista has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." and removes the icon from the tray and refuses to use any of Realtek's settings and/or menu. The only thing I can do is use the Playback Device option, which does not allow you to choose what 'plug' is in which 'jack', like the Realtek's menu allows, which is needed for proper sound configuration. Even though Playback Devices has 5.1, and it reads my device as HD on-board and all (which I have checked it to make sure) it still will not use my rear two speakers. I'v seen many people with similer problems but I have yet to see an answer or solution. If anyone can figure this out or help, I will greatly appriciate it, as I really miss CoD2 and NFS:MW played in 5.1, not to mention my music sucks with just 2.1(or should that be 3.1 cause my center speaker works). Please Help! ![]() |
| | RE: Problem with realtek on-board sound Sorry for all the double posts. Microsoft said it didnt send it.. when obviously it did. "M. Williams" wrote: > I have just installed RC1 and everything works great, except my sound. I have > never had a problem out of it, even with the Beta 2, but with the new RC1 I > cannot get 5.1 to work. Iv tried the auto-update that came with RC1 and it > would not allow me to open or setup my speaker configuration in any way > through Realtek's suplied menus and options, but I can go through the > Playback Devices option and still set things to 5.1. But Even setting that to > 5.1, it still will not play any sound through my back left or right speaker. > I uninstalled the driver, then installed the driver from Realtek's website > for Vista, and still I have no working Realtek menus, and Im still limited to > 2.1. > > Upon attempting to open the Realtek icon in the tray or control panel, it > brings up an error saying "HD Audio Control Panel for Vista has stopped > working. A problem caused the program to stop working correctly. Windows will > close the program and notify you if a solution is available." and removes the > icon from the tray and refuses to use any of Realtek's settings and/or menu. > The only thing I can do is use the Playback Device option, which does not > allow you to choose what 'plug' is in which 'jack', like the Realtek's menu > allows, which is needed for proper sound configuration. Even though Playback > Devices has 5.1, and it reads my device as HD on-board and all (which I have > checked it to make sure) it still will not use my rear two speakers. I'v seen > many people with similer problems but I have yet to see an answer or > solution. If anyone can figure this out or help, I will greatly appriciate > it, as I really miss CoD2 and NFS:MW played in 5.1, not to mention my music > sucks with just 2.1(or should that be 3.1 cause my center speaker works). > Please Help! ![]() |
| | Re: Problem with realtek on-board sound It is a bug in the web-based newsreader. If it annoys you try the newsreader in Windows Mail. "M. Williams" <MWilliams@discussions.microsoft.com> wrote in message news:AA1C4022-D3B7-4686-B70D-5C4D733B6C46@microsoft.com... > Sorry for all the double posts. Microsoft said it didnt send it.. when > obviously it did. > > "M. Williams" wrote: > >> I have just installed RC1 and everything works great, except my sound. I >> have >> never had a problem out of it, even with the Beta 2, but with the new RC1 >> I >> cannot get 5.1 to work. Iv tried the auto-update that came with RC1 and >> it >> would not allow me to open or setup my speaker configuration in any way >> through Realtek's suplied menus and options, but I can go through the >> Playback Devices option and still set things to 5.1. But Even setting >> that to >> 5.1, it still will not play any sound through my back left or right >> speaker. >> I uninstalled the driver, then installed the driver from Realtek's >> website >> for Vista, and still I have no working Realtek menus, and Im still >> limited to >> 2.1. >> >> Upon attempting to open the Realtek icon in the tray or control panel, it >> brings up an error saying "HD Audio Control Panel for Vista has stopped >> working. A problem caused the program to stop working correctly. Windows >> will >> close the program and notify you if a solution is available." and removes >> the >> icon from the tray and refuses to use any of Realtek's settings and/or >> menu. >> The only thing I can do is use the Playback Device option, which does not >> allow you to choose what 'plug' is in which 'jack', like the Realtek's >> menu >> allows, which is needed for proper sound configuration. Even though >> Playback >> Devices has 5.1, and it reads my device as HD on-board and all (which I >> have >> checked it to make sure) it still will not use my rear two speakers. I'v >> seen >> many people with similer problems but I have yet to see an answer or >> solution. If anyone can figure this out or help, I will greatly >> appriciate >> it, as I really miss CoD2 and NFS:MW played in 5.1, not to mention my >> music >> sucks with just 2.1(or should that be 3.1 cause my center speaker works). >> Please Help! ![]() |
| Realtek problem with analog on-board.. | Vista hardware & devices | |||
| Problem with realtek on-board sound | Vista hardware & devices | |||
| 5.1 sound problems on Realtek ALC655 on board sound. | Vista hardware & devices | |||
| 5.1 sound problem with Realtek ACL655 on board sound | Vista hardware & devices | |||
