Vista - Networking problem
Old 07-01-2008   #1 (permalink)
Vista Home Premium x64
Networking problem
Vista x64 w SP1
When downloading large files and when the screensaver comes on I lose connection to my internet. I have to reset the modem to start back up. The router seems fine but for some reason when the computer goes into it's energy saver mode the downloading ceases. I dont' remember any problems of this sort prior to SP1. Any ideas.
Old 07-01-2008   #2 (permalink)
Patrick Keenan
Re: Networking problem
"LCarter" <guest@xxxxxx-email.com> wrote in message
news:97142a1a342e935bc94802d62ffee55c@xxxxxx-gateway.com...
Quote:
> Vista x64 w SP1
> LCarter
Do you have the system set to allow the network adapter (NIC) to be turned
off to save power? This is in properties for the NIC in device manager -
if it's set this way, turn it OFF, and restart the system. Check in the
system BIOS for similar settings. Basically, be sure that the NIC is
always awake.
HTH
-pk
Networking Problem Vista networking & sharing
NETWORKING PROBLEM Vista General
Problem w/ Networking Vista networking & sharing
Networking Problem - Need a little help Vista networking & sharing
Networking Problem Vista General
