| | Partitioning problem I've tried to shrink my c drive to provide more memory for my recovery d: drive. While the shrink process works the extend stays grayed out for the d: drive. I noticed that the graphic shows the unallocated space to the right of the c drive. How can I use disk management to extend my d partition, or is it possible to use diskpart. If diskpart do i shrink and then extend or does diskpart do both when performing the extend function |
| | Re: Partitioning problem "MOC" <mloconn1@xxxxxx> wrote in message news:f3vbk.14260$mh5.7023@xxxxxx Quote: > I've tried to shrink my c drive to provide more memory for my recovery d: > drive. While the shrink process works the extend stays grayed out for the > d: drive. I noticed that the graphic shows the unallocated space to the > right of the c drive. How can I use disk management to extend my d > partition, or is it possible to use diskpart. If diskpart do i shrink and > then extend or does diskpart do both when performing the extend function > If the recovery partition was created by the manufacturer/vendor, leave it as it is.. make no changes to it.. -- Mike Hall - MVP How to construct a good post.. http://dts-l.com/goodpost.htm How to use the Microsoft Product Support Newsgroups.. http://support.microsoft.com/default...help&style=toc Mike's Window - My Blog.. http://msmvps.com/blogs/mikehall/default.aspx |
| Partitioning problem | General Discussion | |||
| Disk partitioning problem | Vista General | |||
| Disk Management - Partitioning problem | Vista account administration | |||
| partitioning problem | General Discussion | |||
| Disc Partitioning Problem with new Dell XPS Laptop | Vista General | |||
