| | Really annoying problems that i cant seem to fix I quite litterly have no idea whats causing these problems. ok heres whats going on previous install of vista home premium had a virus, so i reformatted the hd and reinstalled vista apon using windows update, it froze around update #25, and windows modules installer stopped working but thats only 1 problem Now i have a issue with the windows licensing service, one second my windows is legit, the next it isnt, the next windows licensing stops working ive tried to reinstall 5+ times now, on 2 different harddrives, and it does the same thing on both -- Bruno89 |
| | Re: Really annoying problems that i cant seem to fix Bruno89 wrote: Quote: > I quite litterly have no idea whats causing these problems. > > ok heres whats going on > > previous install of vista home premium had a virus, so i reformatted > the hd and reinstalled vista > > apon using windows update, it froze around update #25, and windows > modules installer stopped working > > but thats only 1 problem > > Now i have a issue with the windows licensing service, one second my > windows is legit, the next it isnt, the next windows licensing stops > working > > > > ive tried to reinstall 5+ times now, on 2 different harddrives, and it > does the same thing on both > reinstall using the Dell (or other manufacturer) method or do you have a retail Vista DVD? If you have a retail version there may be some drivers for the motherboard missing or wrong, that by itself could possible explain why you are not getting anywhere. If you built the machine yourself and you have CDs that came with the motherboard you need to format the drive and reinstall the CD stuff before trying Vista. If you read Dave's post then maybe you could try testing the RAM before ever starting with Vista. You will need to be able to burn a CD to do that. Can you use another machine to do that? http://www.pugetsystems.com/help/memtestcd.php Also if you can, make sure all Memory sticks and cards are securely installed in the case. |
| | Re: Really annoying problems that i cant seem to fix Charlie Tame;670915 Wrote: Quote: > Bruno89 wrote:- > I quite litterly have no idea whats causing these problems. > > ok heres whats going on > > previous install of vista home premium had a virus, so i reformatted > the hd and reinstalled vista > > apon using windows update, it froze around update #25, and windows > modules installer stopped working > > but thats only 1 problem > > Now i have a issue with the windows licensing service, one second my > windows is legit, the next it isnt, the next windows licensing stops > working > > > > ive tried to reinstall 5+ times now, on 2 different harddrives, and > it > does the same thing on both > - > > Is this a machine you built yourself or something like a Dell? Did you > > reinstall using the Dell (or other manufacturer) method or do you have > a > retail Vista DVD? > > If you have a retail version there may be some drivers for the > motherboard missing or wrong, that by itself could possible explain why > > you are not getting anywhere. If you built the machine yourself and you > > have CDs that came with the motherboard you need to format the drive > and > reinstall the CD stuff before trying Vista. > > If you read Dave's post then maybe you could try testing the RAM before > > ever starting with Vista. You will need to be able to burn a CD to do > that. Can you use another machine to do that? > > 'MemTest86 Memory Test (CD)' > (http://www.pugetsystems.com/help/memtestcd.php) > > Also if you can, make sure all Memory sticks and cards are securely > installed in the case. im going to try the memory test, all my drivers for the motherboard work, ive installed vista previously and it worked fine, but i believe it is hardware, i put my old 2x512 sticks of ddr2 ram back in, and so far no errors have appeared, and vista is staying activated, im going to run the memory test with the other ram in and see what it says but yes i have retail vista home premium, bought it from bestbuy, but this one works fine, and ill burn the cd in a min, and reply with the results later on -- Bruno89 |
| | Re: Really annoying problems that i cant seem to fix no memory problems, it all came up clean, but i put my old ram in, and the install went flawless, but i got stop error 0x0000050 on my first boot, 2nd boot started, and so far ive been good, windows was activated, and im starting the updates dling -- Bruno89 |
| | Re: Really annoying problems that i cant seem to fix well um, it worked fine for a while, it updated till update 41/60, and then windows modules installer stopped working, and then windows licensing software stopped working and now my windows is validated, but i cannot install any updates, i also cannot even install vista sp1 it throws out a error which is 0x0800736CC -- Bruno89 |
| Brand new computer, two annoying problems... | Software | |||
| Annoying Maintenance Problems | Vista performance & maintenance | |||
| Some very annoying problems ive been having... can anyone help? | Vista General | |||
| Annoying product key problems | Vista hardware & devices | |||
| What is really annoying | Vista General | |||
