Vista - VPN Problem
Old 09-12-2006   #1 (permalink)
Rick Simmons
VPN Problem
I have (or so I thought) successfully set up my VPN connection as to get
E-Mail from work. It "dials" and connects just fine. However, talking to
my network admin, the username and password are getting cut off on his end.
I've walked thru all my settings and he says they are correct. I'm curious
if I've missed something with Windows Firewall.
Any ideas would be greatly appreciated.
Running build 5600 RC1.
Thanks,
Rick
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
