| | Problems shutting down I'm running activated RC1, and was totally impressed with the speed improvements over Beta 2. For some reason though, it's now taking over 10 minutes to shut down and last night it automatically rebooted to a screen similar to the old dual-boot screen saying that Windows didn't shut down properly and suggested starting in safe mode. I let it boot normally and the error reporting popup appeared but after checking it just closed, not even saying there is no current fix and to check back later. It's about the 5th time the slow shut-down has occurred, but the first that it didn't shut down at all and rebooted. I'm wondering if PC-Cillin has anything to do with it. does anyone know of any other anti-virus programs with demos that will run on Vista? Anyone else having shut-down problems? |
| | Re: Problems shutting down I'm not having any problems here with Vista nor PC-Cillin, or shutting down problems. Did you Defrag the hard drive in Vista? I remember the shut down was slow before doing a complete defrag of my hard drives. "johndw" <johndw@discussions.microsoft.com> wrote in message news:F078874D-7951-472B-85EA-BC185597DA68@microsoft.com... > I'm running activated RC1, and was totally impressed with the speed > improvements over Beta 2. For some reason though, it's now taking over 10 > minutes to shut down and last night it automatically rebooted to a screen > similar to the old dual-boot screen saying that Windows didn't shut down > properly and suggested starting in safe mode. I let it boot normally and > the > error reporting popup appeared but after checking it just closed, not even > saying there is no current fix and to check back later. It's about the > 5th > time the slow shut-down has occurred, but the first that it didn't shut > down > at all and rebooted. > > I'm wondering if PC-Cillin has anything to do with it. does anyone know > of > any other anti-virus programs with demos that will run on Vista? Anyone > else > having shut-down problems? |
| | Re: Problems shutting down Yeah, I did - Twice in three days. Also did a disk cleanup. I used the spyware module in PC-Cillin (which I think is horrible compared to Spyware Doctor, but I haven't tried to install that yet on Vista) and I hope I didn't remove something I shouldn't have. "Ted F" wrote: > I'm not having any problems here with Vista nor PC-Cillin, or shutting down > problems. > > Did you Defrag the hard drive in Vista? > > I remember the shut down was slow before doing a complete defrag of my hard > drives. > > > "johndw" <johndw@discussions.microsoft.com> wrote in message > news:F078874D-7951-472B-85EA-BC185597DA68@microsoft.com... > > I'm running activated RC1, and was totally impressed with the speed > > improvements over Beta 2. For some reason though, it's now taking over 10 > > minutes to shut down and last night it automatically rebooted to a screen > > similar to the old dual-boot screen saying that Windows didn't shut down > > properly and suggested starting in safe mode. I let it boot normally and > > the > > error reporting popup appeared but after checking it just closed, not even > > saying there is no current fix and to check back later. It's about the > > 5th > > time the slow shut-down has occurred, but the first that it didn't shut > > down > > at all and rebooted. > > > > I'm wondering if PC-Cillin has anything to do with it. does anyone know > > of > > any other anti-virus programs with demos that will run on Vista? Anyone > > else > > having shut-down problems? > > > |
| | Re: Problems shutting down No I don't think...If you did remove something you would see lot of strange problems. "johndw" <johndw@discussions.microsoft.com> wrote in message news:378469F0-867E-4E0C-A788-72BEEA647124@microsoft.com... > Yeah, I did - Twice in three days. Also did a disk cleanup. I used the > spyware module in PC-Cillin (which I think is horrible compared to Spyware > Doctor, but I haven't tried to install that yet on Vista) and I hope I > didn't > remove something I shouldn't have. > > "Ted F" wrote: > >> I'm not having any problems here with Vista nor PC-Cillin, or shutting >> down >> problems. >> >> Did you Defrag the hard drive in Vista? >> >> I remember the shut down was slow before doing a complete defrag of my >> hard >> drives. >> >> >> "johndw" <johndw@discussions.microsoft.com> wrote in message >> news:F078874D-7951-472B-85EA-BC185597DA68@microsoft.com... >> > I'm running activated RC1, and was totally impressed with the speed >> > improvements over Beta 2. For some reason though, it's now taking over >> > 10 >> > minutes to shut down and last night it automatically rebooted to a >> > screen >> > similar to the old dual-boot screen saying that Windows didn't shut >> > down >> > properly and suggested starting in safe mode. I let it boot normally >> > and >> > the >> > error reporting popup appeared but after checking it just closed, not >> > even >> > saying there is no current fix and to check back later. It's about the >> > 5th >> > time the slow shut-down has occurred, but the first that it didn't shut >> > down >> > at all and rebooted. >> > >> > I'm wondering if PC-Cillin has anything to do with it. does anyone >> > know >> > of >> > any other anti-virus programs with demos that will run on Vista? >> > Anyone >> > else >> > having shut-down problems? >> >> >> |
| | Re: Problems shutting down Hi Guys, I'm seeing the same problem in about 1 out of every 3 shutdowns and have on a couple of occasions had the good old BSOD at the end of shutdown process. Same with error reporting... checks and dissapears... am just waiting for the "You're on your own mate!" message. Also running PC-Cillin and would also like to know what's going on as my system checks out clean and happy. -- Muppet "Just when I''m about to make ends meet somebody moves the ends" "Ted F" wrote: > No I don't think...If you did remove something you would see lot of strange > problems. > > > "johndw" <johndw@discussions.microsoft.com> wrote in message > news:378469F0-867E-4E0C-A788-72BEEA647124@microsoft.com... > > Yeah, I did - Twice in three days. Also did a disk cleanup. I used the > > spyware module in PC-Cillin (which I think is horrible compared to Spyware > > Doctor, but I haven't tried to install that yet on Vista) and I hope I > > didn't > > remove something I shouldn't have. > > > > "Ted F" wrote: > > > >> I'm not having any problems here with Vista nor PC-Cillin, or shutting > >> down > >> problems. > >> > >> Did you Defrag the hard drive in Vista? > >> > >> I remember the shut down was slow before doing a complete defrag of my > >> hard > >> drives. > >> > >> > >> "johndw" <johndw@discussions.microsoft.com> wrote in message > >> news:F078874D-7951-472B-85EA-BC185597DA68@microsoft.com... > >> > I'm running activated RC1, and was totally impressed with the speed > >> > improvements over Beta 2. For some reason though, it's now taking over > >> > 10 > >> > minutes to shut down and last night it automatically rebooted to a > >> > screen > >> > similar to the old dual-boot screen saying that Windows didn't shut > >> > down > >> > properly and suggested starting in safe mode. I let it boot normally > >> > and > >> > the > >> > error reporting popup appeared but after checking it just closed, not > >> > even > >> > saying there is no current fix and to check back later. It's about the > >> > 5th > >> > time the slow shut-down has occurred, but the first that it didn't shut > >> > down > >> > at all and rebooted. > >> > > >> > I'm wondering if PC-Cillin has anything to do with it. does anyone > >> > know > >> > of > >> > any other anti-virus programs with demos that will run on Vista? > >> > Anyone > >> > else > >> > having shut-down problems? > >> > >> > >> > > > |
| | #6 (permalink) |
| | Re: Problems shutting down Hi, Firstly, I noticed nothing (in fact the speed of shutdown was improved from beta 2 imo and i am v. impressed) HOWEVER, on my desktop it is much faster than on my laptop (which isnt bad, but u can notice a difference). After defragging (not a big fan of the new defragger but it works) it does improve speed and shutdown/start-up times imo. Also note, on beta 2 I had PC Cillin installed as it was the only one MS told you about, however since having RC1, I have used Avast anti-virus, which even the free version is brilliant! and no slow down and no hick-ups! (yet). So I wouldnt say its totally down to PC-Cillin, however I dont think (from my experience) it helps in any way. "johndw" <johndw@discussions.microsoft.com> wrote in message news:F078874D-7951-472B-85EA-BC185597DA68@microsoft.com... > I'm running activated RC1, and was totally impressed with the speed > improvements over Beta 2. For some reason though, it's now taking over 10 > minutes to shut down and last night it automatically rebooted to a screen > similar to the old dual-boot screen saying that Windows didn't shut down > properly and suggested starting in safe mode. I let it boot normally and > the > error reporting popup appeared but after checking it just closed, not even > saying there is no current fix and to check back later. It's about the > 5th > time the slow shut-down has occurred, but the first that it didn't shut > down > at all and rebooted. > > I'm wondering if PC-Cillin has anything to do with it. does anyone know > of > any other anti-virus programs with demos that will run on Vista? Anyone > else > having shut-down problems? |
| | #7 (permalink) |
| | Re: Problems shutting down Hi Mark, Thanks for the info. I'll remove PC-Cillin and try the Avast anti-virus, not too impressed with the PC-Cillin anyway. I'll swap, test and feed back then we'll know one way or another. -- Muppet "Just when I''m about to make ends meet somebody moves the ends" "Marc Nutty" wrote: > Hi, > > Firstly, I noticed nothing (in fact the speed of shutdown was improved from > beta 2 imo and i am v. impressed) > > HOWEVER, on my desktop it is much faster than on my laptop (which isnt bad, > but u can notice a difference). After defragging (not a big fan of the new > defragger but it works) it does improve speed and shutdown/start-up times > imo. > > Also note, on beta 2 I had PC Cillin installed as it was the only one MS > told you about, however since having RC1, I have used Avast anti-virus, > which even the free version is brilliant! and no slow down and no hick-ups! > (yet). > > So I wouldnt say its totally down to PC-Cillin, however I dont think (from > my experience) it helps in any way. > > > "johndw" <johndw@discussions.microsoft.com> wrote in message > news:F078874D-7951-472B-85EA-BC185597DA68@microsoft.com... > > I'm running activated RC1, and was totally impressed with the speed > > improvements over Beta 2. For some reason though, it's now taking over 10 > > minutes to shut down and last night it automatically rebooted to a screen > > similar to the old dual-boot screen saying that Windows didn't shut down > > properly and suggested starting in safe mode. I let it boot normally and > > the > > error reporting popup appeared but after checking it just closed, not even > > saying there is no current fix and to check back later. It's about the > > 5th > > time the slow shut-down has occurred, but the first that it didn't shut > > down > > at all and rebooted. > > > > I'm wondering if PC-Cillin has anything to do with it. does anyone know > > of > > any other anti-virus programs with demos that will run on Vista? Anyone > > else > > having shut-down problems? > > |
| | #8 (permalink) |
| | Re: Problems shutting down Hi again Marc, Sorry for mispelling your name in my last... brain was thinking I'd done it wrong as finger was pressing post! Fingers must be too fast for brain.... or brain too slow.... whatever, once again my apologies. -- Muppet "Just when I''m about to make ends meet somebody moves the ends" "Marc Nutty" wrote: > Hi, > > Firstly, I noticed nothing (in fact the speed of shutdown was improved from > beta 2 imo and i am v. impressed) > > HOWEVER, on my desktop it is much faster than on my laptop (which isnt bad, > but u can notice a difference). After defragging (not a big fan of the new > defragger but it works) it does improve speed and shutdown/start-up times > imo. > > Also note, on beta 2 I had PC Cillin installed as it was the only one MS > told you about, however since having RC1, I have used Avast anti-virus, > which even the free version is brilliant! and no slow down and no hick-ups! > (yet). > > So I wouldnt say its totally down to PC-Cillin, however I dont think (from > my experience) it helps in any way. > > > "johndw" <johndw@discussions.microsoft.com> wrote in message > news:F078874D-7951-472B-85EA-BC185597DA68@microsoft.com... > > I'm running activated RC1, and was totally impressed with the speed > > improvements over Beta 2. For some reason though, it's now taking over 10 > > minutes to shut down and last night it automatically rebooted to a screen > > similar to the old dual-boot screen saying that Windows didn't shut down > > properly and suggested starting in safe mode. I let it boot normally and > > the > > error reporting popup appeared but after checking it just closed, not even > > saying there is no current fix and to check back later. It's about the > > 5th > > time the slow shut-down has occurred, but the first that it didn't shut > > down > > at all and rebooted. > > > > I'm wondering if PC-Cillin has anything to do with it. does anyone know > > of > > any other anti-virus programs with demos that will run on Vista? Anyone > > else > > having shut-down problems? > > |
| | #9 (permalink) |
| | Re: Problems shutting down lol, your ok, i sometimes think my fingers are too fast for their own good too lol "MuppetSteve" <MuppetSteve@discussions.microsoft.com> wrote in message news:B4FADD67-A99C-47CE-BC1A-C573B408E8DD@microsoft.com... > Hi again Marc, > Sorry for mispelling your name in my last... brain was thinking I'd done > it > wrong as finger was pressing post! Fingers must be too fast for brain.... > or > brain too slow.... whatever, once again my apologies. > -- > Muppet > > "Just when I''m about to make ends meet somebody moves the ends" > > > "Marc Nutty" wrote: > >> Hi, >> >> Firstly, I noticed nothing (in fact the speed of shutdown was improved >> from >> beta 2 imo and i am v. impressed) >> >> HOWEVER, on my desktop it is much faster than on my laptop (which isnt >> bad, >> but u can notice a difference). After defragging (not a big fan of the >> new >> defragger but it works) it does improve speed and shutdown/start-up times >> imo. >> >> Also note, on beta 2 I had PC Cillin installed as it was the only one MS >> told you about, however since having RC1, I have used Avast anti-virus, >> which even the free version is brilliant! and no slow down and no >> hick-ups! >> (yet). >> >> So I wouldnt say its totally down to PC-Cillin, however I dont think >> (from >> my experience) it helps in any way. >> >> >> "johndw" <johndw@discussions.microsoft.com> wrote in message >> news:F078874D-7951-472B-85EA-BC185597DA68@microsoft.com... >> > I'm running activated RC1, and was totally impressed with the speed >> > improvements over Beta 2. For some reason though, it's now taking over >> > 10 >> > minutes to shut down and last night it automatically rebooted to a >> > screen >> > similar to the old dual-boot screen saying that Windows didn't shut >> > down >> > properly and suggested starting in safe mode. I let it boot normally >> > and >> > the >> > error reporting popup appeared but after checking it just closed, not >> > even >> > saying there is no current fix and to check back later. It's about the >> > 5th >> > time the slow shut-down has occurred, but the first that it didn't shut >> > down >> > at all and rebooted. >> > >> > I'm wondering if PC-Cillin has anything to do with it. does anyone >> > know >> > of >> > any other anti-virus programs with demos that will run on Vista? >> > Anyone >> > else >> > having shut-down problems? >> >> |
| | #10 (permalink) |
| | RE: Problems shutting down Hi again, I've now uninstalled PC-Cillin from machine and done 4 restarts; 2 OK, 1 hang and 1 BSOD so it's not PC-Cillin A thought from one of the other thread re sleep mode problems there's a query asking if the problem might be related to older motherboards; could this be a case here? My board is over 4 years old with the last BIOS update 2 1/2 years or so ago. How old is your board John? -- Muppet "Just when I''m about to make ends meet somebody moves the ends" "johndw" wrote: > I'm running activated RC1, and was totally impressed with the speed > improvements over Beta 2. For some reason though, it's now taking over 10 > minutes to shut down and last night it automatically rebooted to a screen > similar to the old dual-boot screen saying that Windows didn't shut down > properly and suggested starting in safe mode. I let it boot normally and the > error reporting popup appeared but after checking it just closed, not even > saying there is no current fix and to check back later. It's about the 5th > time the slow shut-down has occurred, but the first that it didn't shut down > at all and rebooted. > > I'm wondering if PC-Cillin has anything to do with it. does anyone know of > any other anti-virus programs with demos that will run on Vista? Anyone else > having shut-down problems? |
| Problems restarting and shutting down | Vista hardware & devices | |||
| Problems shutting down Mail... | Live Mail | |||
| Problems shutting down vista | Vista General | |||
| RE: Problems with shutting down | Vista account administration | |||
| Shutting down problems | Vista installation & setup | |||
