Vista - Dreamscene MPEG4 causes "desktop" problem
Old 07-14-2008   #1 (permalink)
Rod
Hi
running Vista Ultiamte...3gb RAM and graphics card running 256MB dedicated
memory.
I have installed Ultimate Extras. But whenever I try and 'use' a Dreamscene
MPEG4 as my desktop, it runs fine for a while ( a minute or so) then my
desktop goes a solid black color and I get "Dreamscene has caused a system
error" dialog box. If I use a .WMV (Windows Movie File?) in the list of
dreamscene content, it runs fine...all the time.
I cant find how to uninstall any dreamscene content in order to re-install
it...a solution someone else posted here. But Add/Remove programs does not
list dreamscene content, and when I look at the list of downloaded updates,
I can see the dreamscene content, but no delete or uninstall option.
Any thoughts please?
Rod
Old 07-15-2008   #2 (permalink)
Rod
Re: Dreamscene MPEG4 causes "desktop" problem
No-one?????
"Rod" <rdavies1@xxxxxx> wrote in message
news:OB6t2oZ5IHA.300@xxxxxx
Quote:
> Hi
> running Vista Ultimate...3gb RAM and graphics card running 256MB dedicated
> memory.
> Dreamscene MPEG4 as my desktop, it runs fine for a while ( a minute or so)
> then my desktop goes a solid black color and I get "Dreamscene has caused
> a system error" dialog box. If I use a .WMV (Windows Movie File?) in the
> list of dreamscene content, it runs fine...all the time.
> updates, I can see the dreamscene content, but no delete or uninstall
> option.
> Rod
Old 07-20-2008   #3 (permalink)
zachd [MSFT]
Why would reinstalling DreamScene help?
What MPEG4 codec are you trying to use? As noted, DreamScene does not
support MPEG4 by default, so if you're plugging in some bad MPEG4 codec,
that might be the source of your error. =\
Speaking for myself only.
See http://zachd.com/pss/pss.html for some helpful WMP info.
Quote:
> Hi
> memory.
> option.
> Rod
Old 07-21-2008   #4 (permalink)
Rod
Trying to use the Windows Dreamscene Content under Personalise/Change
Desktop Display/Windows Dreamscene Content
I thought these were MPEG4's ???? But they are listed simply as MPEGs... and
they STILL cause my system to revert to a solid black desktop display after
a few seconds of functioing ok...so, they are the Dreamscene MPEGs as
downloaded as an Ultimate Extras. The Windows Movies play perfectly ok...
Rgds
Rod
"zachd [MSFT]" <zachd@xxxxxx> wrote in message
news:ubijHcs6IHA.1420@xxxxxx
> rights.
Quote:
>> Hi
>> dedicated memory.
>> so) then my desktop goes a solid black color and I get "Dreamscene has
>> caused a system error" dialog box. If I use a .WMV (Windows Movie File?)
>> in the list of dreamscene content, it runs fine...all the time.
>> re-install it...a solution someone else posted here. But Add/Remove
>> programs does not list dreamscene content, and when I look at the list of
>> downloaded updates, I can see the dreamscene content, but no delete or
>> uninstall option.
>> Rod
Old 07-21-2008   #5 (permalink)
zachd [MSFT]
What's the filename for a file that doesn't work?
Do these files play back correctly in Windows Media Player?
news:%23VXNuBy6IHA.3672@xxxxxx
> and they STILL cause my system to revert to a solid black desktop display
> after a few seconds of functioing ok...so, they are the Dreamscene MPEGs
> as downloaded as an Ultimate Extras. The Windows Movies play perfectly
> ok...
> Rgds
> Rod
>> rights.
Quote:
>>> Hi
>>> dedicated memory.
>>> of downloaded updates, I can see the dreamscene content, but no delete
>>> Rod
Old 07-22-2008   #6 (permalink)
Rod
Hi
These are files found when I right click on Desktop then go thru
Personalise / Desktop Background / Windows Dreamscene Content.
There are about 11 MPEGS and 3 WMVs there. All MPEGS cause a solid black
screen, all WMVs play as a movie'd desktop.
I can't locate theme any other way, so cant see if WMP plays them, and when
I do find them using method as above I cant right click on them to see their
Properties.
I apologise for being thick on this, I am normally a bit better at my own
troubleshooting. And for seemingly random responses to your very valid
questions. I am in Australia and when you're awake, I am probably asleep!!
Rgds
Rod
news:%23FcGRo36IHA.5440@xxxxxx
> rights.
>> ok...
>> Rgds
>> Rod
>>> rights.
>>>> Hi
>>>> dedicated memory.
>>>> File?) in the list of dreamscene content, it runs fine...all the time.
>>>> Rod
Old 07-22-2008   #7 (permalink)
Rod
OOppss...found them. Under
C:\Windows\Web\Windows DreamScene...
an example name is vid1337.mpg....
and yes they play fine in WMP.
But they obviously "loop", so I am thinking that when the video is "supposed
to start again as the desktop image" it somehow freezes/crashes???
Yet the WMV files do...
Rgds
Rod
> rights.
>> ok...
>> Rgds
>> Rod
>>> rights.
>>>> Hi
>>>> dedicated memory.
>>>> Rod
Old 07-22-2008   #8 (permalink)
zachd [MSFT]
If you turn on Repeat in the player, do they work there?
news:OXeLQU86IHA.5024@xxxxxx
> "supposed to start again as the desktop image" it somehow
> freezes/crashes???
> Rgds
> Rod
>> rights.
>>> display after a few seconds of functioing ok...so, they are the
>>> Dreamscene MPEGs as downloaded as an Ultimate Extras. The Windows Movies
>>> Rgds
>>> Rod
>>>> codec, that might be the source of your error. =\
>>>> rights.
>>>>> Hi
>>>>> dedicated memory.
>>>>> Rod
Old 07-23-2008   #9 (permalink)
Rod
Yes, they give a brief 'stutter', then start again.
news:eiDpIz96IHA.4204@xxxxxx
> rights.
>> freezes/crashes???
>> Rgds
>> Rod
>>> rights.
>>>> MPEGs... and they STILL cause my system to revert to a solid black
>>>> desktop display after a few seconds of functioing ok...so, they are the
>>>> Rgds
>>>> Rod
>>>>> rights.
>>>>>> Hi
>>>>>> dedicated memory.
>>>>>> or so) then my desktop goes a solid black color and I get "Dreamscene
>>>>>> has caused a system error" dialog box. If I use a .WMV (Windows Movie
>>>>>> time.
>>>>>> list of downloaded updates, I can see the dreamscene content, but no
>>>>>> Rod
Old 07-24-2008   #10 (permalink)
zachd [MSFT]
Are you getting any crash events for that ""system error"" in the Problem
Reports and Solutions Center log?
What's the exact text of the error message that you get when it reports an
error from DreamScene?
news:OvBBcRJ7IHA.5024@xxxxxx
>> rights.
>>> freezes/crashes???
>>> Rgds
>>> Rod
>>>> rights.
>>>>> the Dreamscene MPEGs as downloaded as an Ultimate Extras. The Windows
>>>>> Rgds
>>>>> Rod
>>>>>> not support MPEG4 by default, so if you're plugging in some bad MPEG4
>>>>>> rights.
>>>>>>> Hi
>>>>>>> dedicated memory.
>>>>>>> "Dreamscene has caused a system error" dialog box. If I use a .WMV
>>>>>>> (Windows Movie File?) in the list of dreamscene content, it runs
>>>>>>> Rod
Anno 1404 "save/load" problem and using "runas.exe" Gaming
Windows Live Mail (Desktop) "Move To" problem Live Mail
New Problem - "From" Address format in "Microsoft Communities" Live Mail
Error "Windows DreamScene can't run as your desktop is now configu Vista General
