Alex Clayton wrote:Are you talking about Windows Mail and NNTP? If you are talking about WM
> Damn thing is driving me nuts. All of a sudden today my Usenet feed
> keeps going out. machine keeps asking me to log on over and over and
> even though the box is checked to save password it is still gone next
> time. Finally will let me on, then will not send messages, same thing
> over and over asking for me to log on. I finally loaded a free news feed
> that is working fine. My ISP says nothing wrong on their end, and when I
> went and tried my desktop the feed is fine it's an XP. Any ideas what
> this (Vista HP) thing is doing?
and NNTP, then WM will loose the User-Id and psw for authentication.
You can give it the credentials and tell it to save them. It will work
for a second and loose them again, when repeated attempts are made to
give the credentials and save them.
This has only happened to me about five times, but what I find that
works is shut down WM, start it back-up, go to the account, set it
manually and then it will hold. But a couple of times when I did that, I
had to boot the machine to get WM to hold the user-id and psw.
