| Vista Home Premium 32bit | Vista Home Premium 32bit 4 gig Ram problem Hi all Recently I had a problem with my RAID and had to wipe every thing now I have everything installed, but I have 4 sticks of Ram (4x1 sticks) but my computer details display that I only have 2gig. I heard there is a check box I need to tick to use maximum memory but to be honest I haven't a clue where to start looking as I lack knowledge in this kind of thing. Any help is welcome. Thanks Vost |
| | Re: Vista Home Premium 32bit 4 gig Ram problem Vostman wrote: Quote: > Hi all > > Recently I had a problem with my RAID and had to wipe every thing now > I have everything installed, but I have 4 sticks of Ram (4x1 sticks) > but my computer details display that I only have 2gig. I heard there > is a check box I need to tick to use maximum memory but to be honest I > haven't a clue where to start looking as I lack knowledge in this kind > of thing. > > Any help is welcome. > > Thanks > > Vost Maybe the following articles will offer some ideas: (929605) The system memory that is reported in the System Information dialog box in Windows Vista is less than you expect if 4 GB of RAM is installed http://support.microsoft.com/kb/929605/en-us (964003) Windows Vista SP1 will report 4 GB of system memory (RAM) on systems that have 4 GB of memory installed http://support.microsoft.com/kb/946003/ -- John Inzer |
| | Re: Vista Home Premium 32bit 4 gig Ram problem Vostman <guest@xxxxxx-email.com> wrote: Quote: > >Hi all > >Recently I had a problem with my RAID and had to wipe every thing now I >have everything installed, but I have 4 sticks of Ram (4x1 sticks) but >my computer details display that I only have 2gig. I heard there is a >check box I need to tick to use maximum memory but to be honest I >haven't a clue where to start looking as I lack knowledge in this kind >of thing. Some of that space must be used to access video RAM, BIOS, etc. What's left over is used for system RAM, which means you will not be able to use a full 4GB of RAM on a 32-bit machine (see http://members.cox.net/slatteryt/RAM.html). The usual result is 3.1 GB or so being used. 2GB sounds quite low, but you should figure out how much RAM is on your video card, some of the new ones have a TON of memory onboard. Vista SP1 always reports the amount of RAM installed, not the amount used. So it will tell you about your 4GB, and never let on that it can't use all of it. -- Tim Slattery MS MVP(Shell/User) Slattery_T@xxxxxx http://members.cox.net/slatteryt |
| vista ultimate x64 | Re: Vista Home Premium 32bit 4 gig Ram problem now vista with sp1 can help for you dude |
| vista ultimate x64 | Re: Vista Home Premium 32bit 4 gig Ram problem even though u use vista sp1 shown u 4gb in the properties but f u use dxdiag.exe u currently running 3.5gb dude,so how will u do to force it to read all the ram in dxdiag |
| | #6 (permalink) |
| vista ultimate x64 | Re: Vista Home Premium 32bit 4 gig Ram problem |
| | #7 (permalink) |
| | #8 (permalink) |
| | RE: Vista Home Premium 32bit 4 gig Ram problem "Vostman" wrote: Quote: > > Hi all > > Recently I had a problem with my RAID and had to wipe every thing now I > have everything installed, but I have 4 sticks of Ram (4x1 sticks) but > my computer details display that I only have 2gig. I heard there is a > check box I need to tick to use maximum memory but to be honest I > haven't a clue where to start looking as I lack knowledge in this kind > of thing. > > Any help is welcome. > > Thanks > > Vost > > > -- > Vostman > microsoft they will explain 32bit can only support 3 GB of ram |
| | #9 (permalink) |
| | Re: Vista Home Premium 32bit 4 gig Ram problem "Tim Slattery" wrote: Quote: > Vostman <guest@xxxxxx-email.com> wrote: > Quote: > > > >Hi all > > > >Recently I had a problem with my RAID and had to wipe every thing now I > >have everything installed, but I have 4 sticks of Ram (4x1 sticks) but > >my computer details display that I only have 2gig. I heard there is a > >check box I need to tick to use maximum memory but to be honest I > >haven't a clue where to start looking as I lack knowledge in this kind > >of thing. > Assuming you have 32-bit Vista, you have a 32-bit (4GB) address space. > Some of that space must be used to access video RAM, BIOS, etc. What's > left over is used for system RAM, which means you will not be able to > use a full 4GB of RAM on a 32-bit machine (see > http://members.cox.net/slatteryt/RAM.html). > > The usual result is 3.1 GB or so being used. 2GB sounds quite low, but > you should figure out how much RAM is on your video card, some of the > new ones have a TON of memory onboard. > > Vista SP1 always reports the amount of RAM installed, not the amount > used. So it will tell you about your 4GB, and never let on that it > can't use all of it. > > -- > Tim Slattery > MS MVP(Shell/User) > Slattery_T@xxxxxx > http://members.cox.net/slatteryt > |
| | #10 (permalink) |
| | Re: Vista Home Premium 32bit 4 gig Ram problem Styme wrote: Quote: > > "Tim Slattery" wrote: > > Quote: >>Vostman <guest@xxxxxx-email.com> wrote: >> >> Quote: >>>Hi all >>> >>>Recently I had a problem with my RAID and had to wipe every thing now I >>>have everything installed, but I have 4 sticks of Ram (4x1 sticks) but >>>my computer details display that I only have 2gig. I heard there is a >>>check box I need to tick to use maximum memory but to be honest I >>>haven't a clue where to start looking as I lack knowledge in this kind >>>of thing. >>Assuming you have 32-bit Vista, you have a 32-bit (4GB) address space. >>Some of that space must be used to access video RAM, BIOS, etc. What's >>left over is used for system RAM, which means you will not be able to >>use a full 4GB of RAM on a 32-bit machine (see >>http://members.cox.net/slatteryt/RAM.html). >> >>The usual result is 3.1 GB or so being used. 2GB sounds quite low, but >>you should figure out how much RAM is on your video card, some of the >>new ones have a TON of memory onboard. >> >>Vista SP1 always reports the amount of RAM installed, not the amount >>used. So it will tell you about your 4GB, and never let on that it >>can't use all of it. >> >>-- >>Tim Slattery >>MS MVP(Shell/User) >>Slattery_T@xxxxxx >>http://members.cox.net/slatteryt >> > > 32BIT will ONLY support 3GB of ram 64BIT will support up to 16GB 3.3, depends on your hardware. The arithmetic is 4GB minus some that is used for accessing the VGA and a few other pieces of I/O gear. -- Cheers, Bob |
| SP2 installation problem in Home Premium 32bit - Arabic language pack? | Windows Updates | |||
| Vista 32bit Home Premium OEM Issues | Drivers | |||
| Installing Vista 32bit (Home Premium OEM) | Vista General | |||
| Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H | Vista General | |||
| Blue Screen! problem of Vista home premium 32bit. | Vista General | |||
