| | MCE Keyboard+remote problem after sleep When I wake up my Vista x86 MCE from sleep, both the MCE keyboard and the MCE remote operates incorrectly. The mouse movement is stuttering and when pressing a key, the computer will react as if the key was kept pressed. Example is trying to write in the adress bar: pressing W once, will cause the cursor to continue entering W's untill another key is pressed. The same goes for the arrow keys and menu keys on both remotes. Restarting or just simply pull out and insert the IR receiver fixes the problem untill next time I wake it up from sleep. As this Windows driver is built in the Vista installation, I can't really see how to try other drivers. Any suggestions would be highly appreciated. |
| | Re: MCE Keyboard+remote problem after sleep The Green Button - Your Media Center Community: http://thegreenbutton.com/ -- Please use the Communities guidelines when posting. http://www.microsoft.com/wn3/locales...help_en-us.htm Mark L. Ferguson MS-MVP https://mvp.support.microsoft.com/profile/Mark.Ferguson "allannissen" <allannissen@xxxxxx> wrote in message news:3B41A26F-7C2F-423F-8D8F-A9EE49413B25@xxxxxx Quote: > When I wake up my Vista x86 MCE from sleep, both the MCE keyboard and the > MCE > remote operates incorrectly. The mouse movement is stuttering and when > pressing a key, the computer will react as if the key was kept pressed. > Example is trying to write in the adress bar: pressing W once, will cause > the cursor to continue entering W's untill another key is pressed. The > same > goes for the arrow keys and menu keys on both remotes. > Restarting or just simply pull out and insert the IR receiver fixes the > problem untill next time I wake it up from sleep. > As this Windows driver is built in the Vista installation, I can't really > see how to try other drivers. > Any suggestions would be highly appreciated. |
| | Re: MCE Keyboard+remote problem after sleep What should I do with this answer????????? "Mark L. Ferguson" wrote: Quote: > The Green Button - Your Media Center Community: http://thegreenbutton.com/ > > -- > Please use the Communities guidelines when posting. > http://www.microsoft.com/wn3/locales...help_en-us.htm > Mark L. Ferguson MS-MVP > https://mvp.support.microsoft.com/profile/Mark.Ferguson > > "allannissen" <allannissen@xxxxxx> wrote in message > news:3B41A26F-7C2F-423F-8D8F-A9EE49413B25@xxxxxx Quote: > > When I wake up my Vista x86 MCE from sleep, both the MCE keyboard and the > > MCE > > remote operates incorrectly. The mouse movement is stuttering and when > > pressing a key, the computer will react as if the key was kept pressed. > > Example is trying to write in the adress bar: pressing W once, will cause > > the cursor to continue entering W's untill another key is pressed. The > > same > > goes for the arrow keys and menu keys on both remotes. > > Restarting or just simply pull out and insert the IR receiver fixes the > > problem untill next time I wake it up from sleep. > > As this Windows driver is built in the Vista installation, I can't really > > see how to try other drivers. > > Any suggestions would be highly appreciated. |
| | Re: MCE Keyboard+remote problem after sleep "allannissen" <allannissen@xxxxxx> wrote in message news:FF3D1AAA-8DBB-406C-AF15-1A49EB35E1A9@xxxxxx Quote: > What should I do with this answer????????? > > "Mark L. Ferguson" wrote: > Quote: >> The Green Button - Your Media Center Community: >> http://thegreenbutton.com/ >> >> -- >> Please use the Communities guidelines when posting. >> http://www.microsoft.com/wn3/locales...help_en-us.htm >> Mark L. Ferguson MS-MVP >> https://mvp.support.microsoft.com/profile/Mark.Ferguson >> >> "allannissen" <allannissen@xxxxxx> wrote in message >> news:3B41A26F-7C2F-423F-8D8F-A9EE49413B25@xxxxxx Quote: >> > When I wake up my Vista x86 MCE from sleep, both the MCE keyboard and >> > the >> > MCE >> > remote operates incorrectly. The mouse movement is stuttering and when >> > pressing a key, the computer will react as if the key was kept pressed. >> > Example is trying to write in the adress bar: pressing W once, will >> > cause >> > the cursor to continue entering W's untill another key is pressed. The >> > same >> > goes for the arrow keys and menu keys on both remotes. >> > Restarting or just simply pull out and insert the IR receiver fixes the >> > problem untill next time I wake it up from sleep. >> > As this Windows driver is built in the Vista installation, I can't >> > really >> > see how to try other drivers. >> > Any suggestions would be highly appreciated. Did you click the link? |
| | Re: MCE Keyboard+remote problem after sleep > Did you click the link? Quote: > but don't waste my time!! |
| Keyboard/mouse goes to sleep | General Discussion | |||
| Sleep/Keyboard problem | General Discussion | |||
| USB Keyboard prevents Sleep. | Vista installation & setup | |||
| No mouse and keyboard after sleep | Vista hardware & devices | |||
| Keyboard will not activate after sleep mode | Vista General | |||
