Vista - Vista RC1 + disk.sys problem = TRUE!
Old 09-13-2006   #1 (permalink)
=?Utf-8?B?VG9tcGE=?=
I'm totally surprised. Yes, i am. I thougt that the installing problem with
"disk.sys" was solved in RC1. But, no my dear Microsoft - it is NOT(Ok i have
not tried to install the 32-bit Vista version yet)!
I was trying to install Beta 2 on my "new" computer. But i gave up after
have tried almost every solution that was presented here.
My computer(I don't mention brands of the 6 internal HDDs They are Serial
ATA 150/300, all but one, that is ATA/133);
A8R32-MVP Deluxe
AMD 4200+ X2
6 internal Hard drives.
1 external, USB 2 = all together almost 2 TB.
1 external/1 internal DVD player/burner
OLD Graphic card RADEON X850XT(will soon be replaced)
Hauppauge HVR-1300 TV-card
Sound Blaster X-Fi Fatal1ty
Allways installed USB peripherals = 12
PSU = Seasonic S12 600W
Well that's what may interest U for this purpose...
I WILL NOT give up this time!!!
Please HELP ME, PLEASE, PLEASE!!!
I hope that you will forgive me for my BAD English...
Old 09-14-2006   #2 (permalink)
Daniel C. Kline
Re: Vista RC1 + disk.sys problem = TRUE!
Hi Tompa,
Based on your configuration, which is as convoluted as mine, I recommend
* Detach/uninstall as much as possible until after the RC1 install. Look at
software and hardware.
* Run the upgrade from a running copy of XP or Vista, don't boot from CD.
(Don't forget to run the upgrade advisor until it is completely happy)
* Be patient with the install ... don't assume it hung. Some stages take
VERY long. The whole process took about 3 hours on my 3.2 Ghz P4.
* After a successful install, start adding your devies and software
systematically, giving your system a chance to determine any problems and
recommend solutions.
It took me a few tries, but I succeeded in upgrading Beta2 to RC1. The best
advise is that the upgrade advisor warnings should be considered
understated. Make them ALL go away. Then deal with the issues after the
upgrade.
Hope this helps. I know it can be frustrating.
"Tompa" <Tompa@discussions.microsoft.com> wrote in message
news:9FBAD19A-483B-4E97-A3A8-42E46C16EBB6@microsoft.com...
> with
> have
> A8R32-MVP Deluxe
> AMD 4200+ X2
Old 09-14-2006   #3 (permalink)
Hi, Daniel.
Tanks!
Hopefully it will work that way.
"Daniel C. Kline" wrote:
> Hi Tompa,
> upgrade.
> > with
> > have
> > A8R32-MVP Deluxe
> > AMD 4200+ X2
Old 09-28-2006   #4 (permalink)
HALLELULIA!!!
IT WORKS!!!!
New BIOS(ver 606) = Successful Vista RC1 installation.
I didn't even have to unplug anything.
Tank you Daniel. U really tried to help med. Tanks.
"Tompa" wrote:
> Hi, Daniel.
> Tanks!
> > Hi Tompa,
> > upgrade.
> > > with
> > > have
> > > A8R32-MVP Deluxe
> > > AMD 4200+ X2
True Image problem restoring backup Vista General
Acronis True Image Rescue Disc Problem Software
Operator -not should get True for whatever -eq 0 gets True (and morefun) PowerShell
True number of true Vista users Vista General
Vista RC1 + disk.sys problem = TRUE Vista General
