Vista - DVD drive problem
Old 07-20-2008   #1 (permalink)
Tree*Rat
DVD drive problem
OK this is doing my nut!
All was working super fine, then all of a sudden my DVD-Writer wont
work! this happened after installing some software. Ah! I thought, no
problem uninstall .... no prob still there, System restore then ... ah
no the system wont restore as it said it encounter problems and could
not do a restore. Balls!!! ... now i have no DVD!!
Device manager is saying
"Windows cannot load the device driver for this hardware. The driver may
be corrupted or missing. (Code 39)
Click 'Check for solutions' to send data about this device to Microsoft
and to see if there is a solution available."
Check for solutions does nothing!, I dont have a driver disk for it to
install but it worked great with default drivers from vista. Any ideas
how i can get this drive working again?
system details.
AthlonX2 dual core 4050e (2.11ghz)
GeForce6050SE, nForce 430 chipset
NEC DVD-RW 355A
350 GIG HDD - SATA
OS Win Vista With SP1
Old 07-20-2008   #2 (permalink)
Patrick Keenan
Re: DVD drive problem
"Tree*Rat" <tree.rat@xxxxxx> wrote in message
news:Xns9AE1CC81317B6squirrelsaladgooglem@xxxxxx
> system details.
> NEC DVD-RW 355A
> 350 GIG HDD - SATA
One of the important, yet missing, details is - what is the software that
you uninstalled? Did it happen to be CD or DVD related?
-pk
Combo RAID1 and standard Drive setup problem - Unallocated Drive General Discussion
DVD-RW drive problem Vista hardware & devices
Problem with my DVD-drive General Discussion
Problem with DVD/CD RW drive Vista hardware & devices
Vista drive has problem, want to copy files to new drive, HOW?? Vista security
