| windows 95 x64 | someone has this problem? i have windows vista ultimate x64 and is installed in a 30 gb partition.after i instaled i remain whit 15 gb free space but after i instal a program there i remain whit 14 gb.whatever driver i install ocupe 1 gb.thats happened when i instal sound,video,lan, driver programs like bsp player,codecs.... i deleted temp nothing change |
| | Re: someone has this problem? "asache" <guest@xxxxxx-email.com> wrote: Quote: > i have windows vista ultimate x64 and is installed in a 30 gb > partition.after i instaled i remain whit 15 gb free space but after i > instal a program there i remain whit 14 gb.whatever driver i install > ocupe 1 gb.thats happened when i instal sound,video,lan, driver > programs like bsp player,codecs.... Charlie42 |
| | RE: someone has this problem? Hi, I suspect that each time you install something Vista is creating a restore point. After the full restore point allocated space is used up (about 15% of your drive) it will begin to delete the oldest restore point as it adds the new and no additional space will be used. -- Paul "asache" wrote: Quote: > > i have windows vista ultimate x64 and is installed in a 30 gb > partition.after i instaled i remain whit 15 gb free space but after i > instal a program there i remain whit 14 gb.whatever driver i install > ocupe 1 gb.thats happened when i instal sound,video,lan, driver programs > like bsp player,codecs.... > > > -- > asache > |
| windows 95 x64 | Re: someone has this problem? "asache" <guest@xxxxxx-email.com> wrote: Quote: > i have windows vista ultimate x64 and is installed in a 30 gb > partition.after i instaled i remain whit 15 gb free space but after i > instal a program there i remain whit 14 gb.whatever driver i install > ocupe 1 gb.thats happened when i instal sound,video,lan, driver > programs like bsp player,codecs.... Charlie42 yes rounded 12.56 gb>>11.56 but i uninstall the driver come 12.56 again or whit some average mb maybe the windows vista is not so good is that dvd that a friend recieved from buying a system dell |
| | Re: someone has this problem? "asache" <guest@xxxxxx-email.com> wrote: Quote: > yes rounded 12.56 gb>>11.56 but i uninstall the driver come 12.56 > again or whit some average mb > maybe the windows vista is not so good is that dvd that a friend > recieved from buying a system dell full gigabyte, but together with the restore point created you may very well reach 1GB, and the same number of used space will reappear because the restore points disk quota is maxed out. You can find the actual number of bytes available in the drive's Properties menu (not rounded up to MBs and GBs): Click Computer > right-click [Drive letter:] > Properties. Charlie42 |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
