Vista - WLAN card wireless network???
Old 07-24-2008   #1 (permalink)
andy t
I have a little popup window which has just recently appeared, and it pops up
generally, when I start up the PC. In the window it reads,
"Dell wireless WLAN card wireless network controller stopped working and was
closed".
"A problem caused the application to stop working correctly. Windows will
notify you if a solution is available".
What does this mean? I do not need the wireless network setup, so does this
mean I have accidentally activated it and if have, can you tell me how it
could be
de- activated?
andy t
Old 07-24-2008   #2 (permalink)
Bob D.
Re: WLAN card wireless network???
You could look here to disable the wireless network. Control Panel ->
Network & Internet -> Network & Sharing Center -> Manage Network
Connections. You may see it listed in there & may be able to disable it.
Bob
"andy t" <andyt@xxxxxx> wrote in message
news:36F2912F-1D01-4613-AF04-0ACD1B033DFD@xxxxxx
>up
> was
> closed".
> this
> could be
> de- activated?
> andy t
Old 07-24-2008   #3 (permalink)
DL
And I believe some Dell's have a switch to turn on/off Wlan
>up
> was
> closed".
> this
> could be
> de- activated?
> andy t
wireless network card? Network & Sharing
Best Wireless PCI Network Card??? Network & Sharing
Want to use USB network adapter instead of internal wlan card Network & Sharing
Dell Wireless WLAN Card Wireless Network Controller has stopped working Network & Sharing
Wireless USB Network card for X64 Network & Sharing
