| | scanning problem, hp f4280 to vista I have a new all-in-one which I have never had before. I scan a document and it goes to Hp photosmart 3.0 and my Documents folder. I cannot copy and paste from the scanned document in either. Is there a solution? could be I just don't know how . Thanks for any help. |
| | Re: scanning problem, hp f4280 to vista It sounds to me like you expect a scanned document to be text, when in fact it's an image of the document. There are Optical Character Recognition (OCR) apps that will do that. -- Please use the Communities guidelines when posting. http://www.microsoft.com/wn3/locales...help_en-us.htm Use the "Ratings" feature. It helps the new users. Mark L. Ferguson MS-MVP https://mvp.support.microsoft.com/profile/Mark.Ferguson "r g traweek" <rgtraweek@xxxxxx> wrote in message news E8C35D5-7190-4ABC-A29E-8A1BEE3E4570@xxxxxxQuote: > I have a new all-in-one which I have never had before. I scan a document > and > it goes to Hp photosmart 3.0 and my Documents folder. I cannot copy and > paste > from the scanned document in either. Is there a solution? could be I just > don't know how . Thanks for any help. |
| | Re: scanning problem, hp f4280 to vista Thanks ,Mark. I understand the problem now .Will seek something to make it work. "Mark L. Ferguson" wrote: Quote: > It sounds to me like you expect a scanned document to be text, when in fact > it's an image of the document. There are Optical Character Recognition (OCR) > apps that will do that. > > -- > Please use the Communities guidelines when posting. > http://www.microsoft.com/wn3/locales...help_en-us.htm > Use the "Ratings" feature. It helps the new users. > Mark L. Ferguson MS-MVP > https://mvp.support.microsoft.com/profile/Mark.Ferguson > > "r g traweek" <rgtraweek@xxxxxx> wrote in message > news E8C35D5-7190-4ABC-A29E-8A1BEE3E4570@xxxxxxQuote: > > I have a new all-in-one which I have never had before. I scan a document > > and > > it goes to Hp photosmart 3.0 and my Documents folder. I cannot copy and > > paste > > from the scanned document in either. Is there a solution? could be I just > > don't know how . Thanks for any help. |
| | Re: scanning problem, hp f4280 to vista For OCR programs, if you should have Microsoft Office 2003 or other versions there is Microsoft Document Imaging which is included as part of the program. My AIO printer had OmniPage 14 Pro as part of it's installation software. While I don't know what software was included with your HP I am reasonably sure that they included some OCR software with the printer/scanner. A model number may also enable us to help you search for the software that was on your install CD. "r g traweek" <rgtraweek@xxxxxx> wrote in message news:7EE7BC32-4506-4EDE-BD48-CDBA6A6F9F98@xxxxxx Quote: > Thanks ,Mark. I understand the problem now .Will seek something to make > it > work. > > "Mark L. Ferguson" wrote: > Quote: >> It sounds to me like you expect a scanned document to be text, when in >> fact >> it's an image of the document. There are Optical Character Recognition >> (OCR) >> apps that will do that. >> >> -- >> Please use the Communities guidelines when posting. >> http://www.microsoft.com/wn3/locales...help_en-us.htm >> Use the "Ratings" feature. It helps the new users. >> Mark L. Ferguson MS-MVP >> https://mvp.support.microsoft.com/profile/Mark.Ferguson >> >> "r g traweek" <rgtraweek@xxxxxx> wrote in message >> news E8C35D5-7190-4ABC-A29E-8A1BEE3E4570@xxxxxxQuote: >> > I have a new all-in-one which I have never had before. I scan a >> > document >> > and >> > it goes to Hp photosmart 3.0 and my Documents folder. I cannot copy and >> > paste >> > from the scanned document in either. Is there a solution? could be I >> > just >> > don't know how . Thanks for any help. |
| Scanning with vista (cant) | Drivers | |||
| having problem scanning with F-Prot | .NET General | |||
| Virus Protection Scanning Problem | Vista security | |||
| Problem scanning | Vista print fax & scan | |||
| Easy Transfer Problem Scanning system | Vista General | |||
