Vista Tutorial - How Long does RC work for?
Old 09-14-2006   #1 (permalink)
Lincoln 6 Echo
Guest
Is there some time period in which RC 1 will run before not letting us to
use it any more? Some sort of evaluation, or is it going to run forever?
Knowing this will help me out in deciding if I am going to seriously test it
out, i.e. spend time installing a bunch of other software and see how it
behaves, or should I just forget about it (if it is going to expire in some
short time)
Thanks,
Petar
Old 09-14-2006   #2 (permalink)
Jupiter Jones [MVP]
Guest
Re: How Long does RC work for?
31 May 2007
Start/Run
Type "winver" ENTER
About the center:
"Evaluation copy. Expires 31/05/2007"
Jupiter Jones [MVP]
http://www3.telus.net/dandemar
http://www.dts-l.org
"Lincoln 6 Echo" <lincoln@6echo.com> wrote in message
news:458713B7-269A-479E-B40F-5C88083877C4@microsoft.com...
> Hi,
> it out, i.e. spend time installing a bunch of other software and see how
> it behaves, or should I just forget about it (if it is going to expire in
> some short time)
> Thanks,
> Petar
Old 09-14-2006   #3 (permalink)
Mark D. VandenBerg
Guest
Click on the Start Orb and type "winver" and your answer will be known.
> Hi,
> some short time)
> Thanks,
> Petar
Old 09-14-2006   #4 (permalink)
Mario Rosario
Guest
How do they figure 4:59 PM? Why not 11:59 PM?
"Jupiter Jones [MVP]" <jones_jupiter@hotnomail.com> wrote in message
news:e9X$cPH2GHA.2036@TK2MSFTNGP05.phx.gbl...
> 31 May 2007
> Start/Run
> Type "winver" ENTER
> About the center:
> Jupiter Jones [MVP]
>> Hi,
>> some short time)
>> Thanks,
>> Petar
Old 09-14-2006   #5 (permalink)
NeoDude
Guest
4:59 PM PST, where Microsoft is. That'll be 11:59 PM GMT.
<DIV>&quot;Mario Rosario&quot; &lt;mario@webacre.com&gt; wrote in message
news:444C82A5-466B-4CCE-BE2C-F5845235DD8B@microsoft.com...</DIV>> How do
>> 31 May 2007
>> Start/Run
>> Type "winver" ENTER
>> About the center:
>> Jupiter Jones [MVP]
>>> Hi,
>>> to use it any more? Some sort of evaluation, or is it going to run
>>> forever?
>>> test it out, i.e. spend time installing a bunch of other software and
>>> see how it behaves, or should I just forget about it (if it is going to
>>> expire in some short time)
>>> Thanks,
>>> Petar
Old 09-15-2006   #6 (permalink)
William
Guest
Curse those Englanders and their GMT!
William
"NeoDude" <alanbunting@hotmail.com> wrote in message news:69B39C70-0E15-4CAD-9D4E-10372A31DDB6@microsoft.com...
>> 31 May 2007
>> Start/Run
>> Type "winver" ENTER
>> About the center:
>> Jupiter Jones [MVP]
>>> Hi,
>>> forever?
>>> Thanks,
>>> Petar
Old 09-15-2006   #7 (permalink)
Mario Rosario
Guest
Ok good idea #$%!@!&!!!
"William" <woogles@charter.net> wrote in message news:6DECAB68-FD0A-4F3D-9028-D4823AD71925@microsoft.com...
William
>> 31 May 2007
>> Start/Run
>> Type "winver" ENTER
>> About the center:
>> Jupiter Jones [MVP]
>>> Hi,
>>> forever?
>>> Thanks,
>>> Petar
Fix for long, long, long deleting and copying of files? Vista General
Long delays on server sending via windows mail to via work email Vista mail
how long defrag work it??? Vista hardware & devices
Vista takes a long time from start to long in on SBS2003 network...... Vista networking & sharing
setting flags takes a long long time Vista mail
