| Guest | Return from Sleep/Lock problem Vista, SP1 I have an issue returning from sleep mode or simply "lock workstation" mode. It works fine if I sleep/lock and return within a few minutes. However, if the system sits for a while, 30 minutes or so, there is a problem when I sign back on. The desktop appears, but most if not all icons are blank. Perhaps two or three out of 60 are displayed properly. They all seem to work, but they are blank. In addition, the hourglass/busy cursor is displayed and does not go away. I checked in Process Explorer, and it shows nothing going on aside form the PE itself and an occasional hit for the mouse and a tiny hit on DPC. There does not appear to be any other process using any CPU time. Yet the hourglass is steady. I can do anything I want on the system (blank icons notwithstanding) EXCEPT log off or shutdown. I can choose them from the start menu but there is no reaction from the system. My WAG is that it is still running the winlogon process and/or that it never completes - although when I've seen that in the past on other systems and other versions of windows it was always visible in process explorer or task manager as an active process taking CPU time. Ideas? |
| Guest | Re: Return from Sleep/Lock problem Please ignore this thread... problem reposted with a different subject as it has expanded in scope. |
| Sleep Return Timeout for Unattended Wake Up | Tutorials | |||
| Return from Sleep with no usb mouse or keyboard | General Discussion | |||
| Lock on sleep | System Security | |||
| Shutdown on return from sleep | Vista General | |||
| Return from sleep mode is strange | Vista performance & maintenance | |||
