Vista - issue: power plan setting keep changing when connecting to interne
Old 08-07-2008   #1 (permalink)
GT
I've always have the balanced as my power plan. Well I just found out today
that everytime i connect to Netzero dial-up internet connection my power plan
automatically change to high performance. How do i stop that?
Old 08-07-2008   #2 (permalink)
Gary S. Terhune
Re: issue: power plan setting keep changing when connecting to interne
Change ISPs? NetZero uses its own dialer, not the one built into Windows.
Look into whatever app NetZero installs to idiot-proof your connection to
them and see if you can turn off this "feature". I doubt that you can. I'm
betting they have some incompatibility between their dialer and any Sleep or
other APM feature (like it won't resume when you come back from your
bathroom break) and their solution is to turn it all off when the dialer is
active. Does it return the settings to what they were when you're finished
and the dialer has unloaded?
Of course, I'm totally guessing, here. I'll bet you'd get another answer
from NetZero, though which would be more correct.....???? Their "Help" makes
no mention of the issue.
Oh, and BTW... Have you updated your NetZero software to the latest? Version
8.5?
(No, I know of no way to make Vista stop it from happening.)
Gary S. Terhune
MS-MVP Shell/User
http://grystmill.com
"GT" <GT@xxxxxx> wrote in message
news:0D3E0628-5945-4197-8995-278C7F071142@xxxxxx
> today
> plan
Solved Power Options Corrupt (power plan unavailable) General Discussion
Changing Power Plan while connected remotely Network & Sharing
issues Power plan keep changing to high performance . Vista hardware & devices
issues Power plan keep changing to high performance. what's wrong? Vista General
Connecting to network works fine, but no connection to the interne Vista networking & sharing
