| | NEED HELP URGENT!!!! Okay I downloaded the 64 bit Vista. The whole thing is downladed and the icon is on my desltop. So I clicked it to start the installation. It asked me to chose a program for it to run. So I clicked Interenet Explorer since it was recommended. Then its sayts the open, save, cancel thing so I click open. Then it gets to the file transfer thing (green bars) which is frozen and doesn't change. Then is goes off and IE 7 opens abd crashes in a second. So now I have no idea on what to do. I can't redownload the file, it says I have 2 product keys. Should I just get the DVD or just forget about it. Oh and when does the CPP end? Thanks |
| | Re: NEED HELP URGENT!!!! NoSpin- From the sound of it, you're not very familiar with burning images to disk. Maybe you should wait for the official release to come out so that you don't have to worry about all that? Also, the instructions on the download page are very clear about what to do after you download the file. Please refer to there for what to do next. Tak Tak Omega Host of TechTAK on KFAR 660am "NoSpinVette" <NoSpinVette@discussions.microsoft.com> wrote in message news:EB498118-2320-48BB-AD40-CB78C421C496@microsoft.com... > Okay I downloaded the 64 bit Vista. The whole thing is downladed and the > icon > is on my desltop. So I clicked it to start the installation. It asked me > to > chose a program for it to run. So I clicked Interenet Explorer since it > was > recommended. Then its sayts the open, save, cancel thing so I click open. > Then it gets to the file transfer thing (green bars) which is frozen and > doesn't change. Then is goes off and IE 7 opens abd crashes in a second. > So > now I have no idea on what to do. I can't redownload the file, it says I > have > 2 product keys. Should I just get the DVD or just forget about it. Oh and > when does the CPP end? Thanks |
| | Re: NEED HELP URGENT!!!! You didn't download a data file that can be run by a Windows program. You didn't download a Windows program. You downloaded the electonic image of a dvd. Now you have to burn the image to a real dvd so it will work in your dvd drive. If you are planning on installing Vista on anything but a test computer completely apart from your primary home computer or your gaming computer, DON'T. As Raven Mill told you, you have not even read the download page. I also point you to the paragraph in red text on that page. "NoSpinVette" <NoSpinVette@discussions.microsoft.com> wrote in message news:EB498118-2320-48BB-AD40-CB78C421C496@microsoft.com... > Okay I downloaded the 64 bit Vista. The whole thing is downladed and the > icon > is on my desltop. So I clicked it to start the installation. It asked me > to > chose a program for it to run. So I clicked Interenet Explorer since it > was > recommended. Then its sayts the open, save, cancel thing so I click open. > Then it gets to the file transfer thing (green bars) which is frozen and > doesn't change. Then is goes off and IE 7 opens abd crashes in a second. > So > now I have no idea on what to do. I can't redownload the file, it says I > have > 2 product keys. Should I just get the DVD or just forget about it. Oh and > when does the CPP end? Thanks |
| URGENT HELP | Vista installation & setup | |||
