| | help with monitor/TV Hi, I recently purchased a dual core Pentium system with Vista Home Premium installed. I could use some help with a problem that may have implications beyond Vista. In previous times I would enable a seamless software/hardware interface with a monitor using a 'monitor.inf' file supplied by manufacturer. In the present case I am trying to interface to a Samsung FP-T5084 plasma HDTV with an innate resolution of 1080x1900. The Samsung can do all the magic of converting between input resolutions, no problem. I am connecting the Vista PC to the HDTV using a 'monitor' or VGA connector and cable. The Vista PC uses Nvidia graphics hardware which should be fairly competent. Vista is reporting that the monitor device is not 'Plug and Play'. It is assigning it has the characteristics of a CRT. Vista software provides a number of built in resolutions and also provisions for custom resolutions. Some of the standard resolutions do not work. For instance, the Samsung cannot sync with 1200x1600 as presently generated by the Vista PC. I have another PC, a Dell laptop running WinXP and equipped with an ATI card and that can transmit 1200x1600 resolution which the Samsung can sync, using the same VGA connector/cable. I think the WinXP PC assumes the extra monitor is a flat panel display like the built in display and not a CRT. I've asked Samsung customer service for an appropriate 'monitor.inf' file but they do not know what I am talking about. I know that a 'montor.inf' file would be helpful for my WinXP PC and I think it would solve the problems with the Vista system. Perhaps there is a template 'monitor.inf' file that can be adapted or perhaps a file from another manufacturer can be used. One other feature of the HDTV/monitor is relevant. One can select between 4:3 aspect ratio or 16:9 aspect ratio which fills the whole screen. Most standard resolutions assume an aspect ratio of 4:3. When I use a standard resolution and select 16:9 aspect ratio, circles become ovals and thin girls become fat. It is my belief that Microsoft graphics is sufficiently sophisticated to make corrections for aspect ratio, if there is some way to tell it about aspect ratio. I think my solution is to acquire an approprtiate 'monitor.inf' file and I hope some one here can link me to one or possibly a utility program with which I can edit one. If I can inform Vista that monitor is not a CRT but is a flat panel display, then maybe I can also get the custom resolution feature to support 1080x1900 high resolution and solve my aspect ratio problem. I presume that Vista is sufficiently general that it can support 1080x1900 high resolution. Help, advice and comment would be appreciated. L. |
| | Re: help with monitor/TV "Vista PC uses Nvidia graphics hardware " I'd ask the computer supplier. Failing that, I'd be looking for updated NVidia drivers. It sounds like you have a driver related problem rather than a Vista problem. "Len" <len017@xxxxxx> wrote in message news:PJ6nk.65626$nD.247@xxxxxx Quote: > Hi, > > I recently purchased a dual core Pentium system with Vista Home Premium > installed. I could use some help with a problem that may have implications > beyond Vista. In previous times I would enable a seamless > software/hardware interface with a monitor using a 'monitor.inf' file > supplied by manufacturer. In the present case I am trying to interface to > a Samsung FP-T5084 plasma HDTV with an innate resolution of 1080x1900. The > Samsung can do all the magic of converting between input resolutions, no > problem. I am connecting the Vista PC to the HDTV using a 'monitor' or VGA > connector and cable. The Vista PC uses Nvidia graphics hardware which > should be fairly competent. Vista is reporting that the monitor device is > not 'Plug and Play'. It is assigning it has the characteristics of a CRT. > Vista software provides a number of built in resolutions and also > provisions for custom resolutions. Some of the standard resolutions do not > work. For instance, the Samsung cannot sync with 1200x1600 as presently > generated by the Vista PC. I have another PC, a Dell laptop running WinXP > and equipped with an ATI card and that can transmit 1200x1600 resolution > which the Samsung can sync, using the same VGA connector/cable. I think > the WinXP PC assumes the extra monitor is a flat panel display like the > built in display and not a CRT. > > I've asked Samsung customer service for an appropriate 'monitor.inf' file > but they do not know what I am talking about. I know that a 'montor.inf' > file would be helpful for my WinXP PC and I think it would solve the > problems with the Vista system. Perhaps there is a template 'monitor.inf' > file that can be adapted or perhaps a file from another manufacturer can > be used. One other feature of the HDTV/monitor is relevant. One can select > between 4:3 aspect ratio or 16:9 aspect ratio which fills the whole > screen. Most standard resolutions assume an aspect ratio of 4:3. When I > use a standard resolution and select 16:9 aspect ratio, circles become > ovals and thin girls become fat. It is my belief that Microsoft graphics > is sufficiently sophisticated to make corrections for aspect ratio, if > there is some way to tell it about aspect ratio. > > I think my solution is to acquire an approprtiate 'monitor.inf' file and I > hope some one here can link me to one or possibly a utility program with > which I can edit one. If I can inform Vista that monitor is not a CRT but > is a flat panel display, then maybe I can also get the custom resolution > feature to support 1080x1900 high resolution and solve my aspect ratio > problem. I presume that Vista is sufficiently general that it can support > 1080x1900 high resolution. > > Help, advice and comment would be appreciated. > > L. > |
| | Re: help with monitor/TV "Patrick Keenan" <test@xxxxxx> wrote Quote: > You need to start with nVidia support, and Samsung, not Vista. this point I would not question nVidia but I would question Samsung. I have contacted Samsung and they are clueless. Below I have attached an INF file for a SONY GDM-C520 Monitor. As you can see, the software makes connections to other files and manipulates registry entries. This is why I think it is premature to question nVidia driver software. I think Sony is a good manufacturer (unlike Samsung. Can you here me Samsung?) The C520 is probably plug and play. PNP tells MS Windows "I'm a C520". Then MS Windows extracts the file below from its catalog and installs the SNYMON51.INF file. In case the customer has a copy of MS Windows that does no behave, then the customer must download the file from Sony (as I have done) and install it manually. If only I could obtain a compatable monitor.inf file for the my samsung I would be happy. I do not know enough to edit the file below to suit my needs. This problem only relates to Vista to the extent that I'm trying to solve the problem in Vista. The problem also exists for my WinXP system. ; ####################################### ; [SNYMON51.INF] ; ; Revision 1.00 July 11, 2002 ; Sony Corporation ; Copyright 2002 ; ####################################### [Version] signature="$CHICAGO$" Class=Monitor ClassGuid={4D36E96E-E325-11CE-BFC1-08002BE10318} Provider=%SONY% CatalogFile=SNYMON51.cat DriverVer=07/11/2002,1.00 [ControlFlags] ExcludeFromSelect.nt=Monitor\SNY01B1 [DestinationDirs] DefaultDestDir=11 GDM-C520.Copyfiles=23 [SourceDisksNames] 1=%DISK%,,, [SourceDisksFiles] sony_d11.icm=1 sony_d93.icm=1 sony_d65.icm=1 sony_d50.icm=1 [Manufacturer] %SONY%=SONY [SONY] %GDM-C520%=GDM-C520.Install, Monitor\SNY01B1 [GDM-C520.Install] DelReg=DEL_CURRENT_REG AddReg=GDM-C520.AddReg, 2048, DPMS CopyFiles=GDM-C520.Copyfiles [DEL_CURRENT_REG] HKR,MODES HKR,,MaxResolution HKR,,DPMS HKR,,ICMProfile [2048] HKR,,MaxResolution,,"2048,1536" [DPMS] HKR,,DPMS,,1 [GDM-C520.AddReg] HKR,"MODES\2048,1536",Mode1,,"30.0-130.0,48.0-170.0,+,+" HKR,,ICMProfile,0,"sony_d93.icm" [GDM-C520.Copyfiles] sony_d11.icm sony_d93.icm sony_d65.icm sony_d50.icm [Strings] DISK="SONY Monitor Information Disk" SONY="SONY Corporation" GDM-C520="SONY GDM-C520" |
| | Re: help with monitor/TV On Aug 9, 1:44 am, "Warp 10" <warpe@xxxxxx> wrote: Quote: > Hello, the solution is easy, since if you install the nvidia drivers from > the nvidia.com site > you will see in your control panel an nvidia icon that is the nvidia > control > panel. > > After pressing it a window like this will open (see screenshot) > > http://www.ixbt.com/video2/images/fw90/cpl_main.png > > Be sure you are using the ADVANCED mode from the option you will see > there. > > then go to the options you will see in this window (see screenshot) > > http://img212.imageshack.us/img212/3...e60hz01mc4.jpg > > and add the correct native resolution for your monitor, have in mind that > the refresh rate will be 60 Hz. > > Hope this helps, tell me if it resolved your issue control panel. Your second .jpg picture confirms my case. In your case it says 'Laptop Display'. In my case I says "Analogue Display" and elsewhere the control panel refers incorrectly to my display as a 'CRT'. CRT means cathode ray tube or cathode ray terminal. A CRT relies on magnetic deflection coils to sweep the electron beams (3 for color) across the phosphor screen. A flat panel display screen does no work that way so there is no reason for the video signal driving a flat panel display to be the same as what is required for a CRT. Ask yourself, how does your system know you have a flat panel? Because of the Microsoft magic of Plug and Play. At boot time or first time your system is booted the 'smart' flat panel display reports "I'm flat, I'm a laptop and I'm smart" and the system loads the appropriate 'monitor.inf' file whose software defines the characteristics of your flat panel display. Samsung enginers are useless and overpaid and they failed to make the product PnP and they are so stupid that they claim ignorance when a customer complains of the lack of appropriate 'monitor.inf' sofware for download. Stupid Samsung. Stupid me for dropping a couple of grand on a Samsung HDTV/monitor. I took the suggestion to upgrade to the latest NVIDIA drivers. I did not notice a difference in performance. Because my software thinks the system is connected to a CRT there are controls to adjust the screen size and position. Such controls make no sense for a flat panel display. I made an adjustament of one pixel and I was able to up the maximum resolution to 1280x1024. This is conclusive proof that the signal being generated is not right. If there is anyone else who has this same problem with a Samsung HDTV/monitor, maybe we can collaborate on a class action legal suit against Samsung and recover damages. CAN YOU HEAR ME SAMSUNG? AM I LOUD ENOUGH? |
keep monitor on | General Discussion | |||
| HELP! Monitor Settings Issues: Can't Alter the Monitor Settings... | Vista hardware & devices | |||
| Closing notebook monitor switches desktop to connected 2nd monitor | Vista General | |||
| 4 screens on one monitor and monitor won't wake up from sleep mode | Vista hardware & devices | |||
| Monitor or Monitor Driver? | Vista hardware & devices | |||
