Vista Forums Home Join Vista Forums Tech Publications Windows 7 Forum Vista Tutorials Webcasts Tags
Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Running both XP and Vista on same computer
Update your Vista Drivers
Thread Tools Display Modes
Old 09-15-2006   #1 (permalink)
=?Utf-8?B?Q2hyaXM=?=
Guest
Could I keep XP as my main os with all of my same settings, and add Vista as
a secondary os?
Old 09-16-2006   #2 (permalink)
Jeff
Guest
Re: Running both XP and Vista on same computer
I am doing that, but I have 3 partitions on my HD. One with XP, one with all
my files (My Docs), and the 3rd with Vista.
You will want XP installed first, and then install Vista. Vista's boot
manager will controll which to boot into. If you want to make changes, you
will have to boot up Vista and go through the My Computer options and edit
them in the boot manager there.
The setup works fine, but I do recommend you at least have 40GB partitions
for Vista, XP, and larger for your files.
I have 2-120GB drives in a Raid striping array (240GB drive) with XP-40,
Vista-40 and ~125GB for my "files" partitions. That way, which ever OS you
boot in to it's easy to find your docs. And with the 40GB OS partitions, it
leaves room to install programs for each OS.
"Chris" <Chris@discussions.microsoft.com> wrote in message
news:1E149C86-34EF-40FF-B1CE-7F53B16E9495@microsoft.com...
> as
> a secondary os?
Old 09-16-2006   #3 (permalink)
Chad Harris
Guest
When ytou do the dual boot, from the Vista desktop you can access your XP
desktop by using C:\Documents and Settings (or whatever drive/letter you use
for XP)\Chri's profile\Desktop and you can access your Vista desktop via
Vista Drive\Users\Chris's Vista Profile\Desktop. You
will find that you have to do a lot of okaying permission to transfer files
from a location on one drive to another but it only takes a second--for
example from a folder on Vista to a folder on the XP drive. The dual boot
works very well.
CH
> as
> a secondary os?
Old 09-16-2006   #4 (permalink)
John Barnes
Guest
Just remember that the RC1 is still buggy and follow Microsofts warning.
While most seem to be able to install with no problems, many have had
problems, up to and including losing use of the other drives. You should
not install on your main computer unless you are fully backed up and even
after install, you still have risks to your system.
> as
> a secondary os?
Old 09-16-2006   #5 (permalink)
Colin Barnhorst
Guest
I fully support John's advice but I go even further and say don't do it. MS
advises not to install Vista in a production environment or on a primary
home computer. They don't qualify that with "unless on another partition or
drive." They just say don't install on your primary home computer. They
have good reasons. If the only computer available to you to try Vista on is
one you and your family rely on then don't install it and simply wait for
Vista to release in January.
You can safely try Vista on such a machine by using Virtual PC or Virtual
Server, however, provided that your computer has sufficient ram.
"John Barnes" <jbarnes@email.net> wrote in message
news:uT7%23u3Y2GHA.4976@TK2MSFTNGP02.phx.gbl...
>> as
>> a secondary os?
Old 09-17-2006   #6 (permalink)
Lang Murphy
Guest
Or by purchasing an additional hard drive on which to install Vista
stand-alone...
Lang
"Colin Barnhorst" <colinbarharst(remove)@msn.com> wrote in message
news:e$D42Bb2GHA.1568@TK2MSFTNGP03.phx.gbl...
>MS advises not to install Vista in a production environment or on a primary
>or drive." They just say don't install on your primary home computer.
>They have good reasons. If the only computer available to you to try Vista
>on is one you and your family rely on then don't install it and simply wait
>for Vista to release in January.
>>> Vista as
>>> a secondary os?
Display Modes
Using my computer as a fax running under Vista Eros Vista print fax & scan 1 03-15-2008 07:06 PM
Restarted my computer and NO sound running vista 32 bit Luchin Vista music pictures video 3 03-07-2008 11:32 PM
Is there any way to fax with this new computer running Vista? mom Vista General 17 09-29-2007 02:18 PM
New Computer Running Slow with Vista Windshadow333 Vista performance & maintenance 3 09-21-2007 08:10 PM
How to check if the computer is running a retail Vista? mr.koolfool Vista General 4 07-15-2007 11:45 AM
Complimentary Industry Resources
Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today!
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
