Vista - Deleting System Restore Point
Old 09-16-2006   #1 (permalink)
=?Utf-8?B?SmltYm8=?=
How do I delete a specific system restore point (i'm using Vista RC1) but not
turn off system restore all together?
Old 09-16-2006   #2 (permalink)
Rick Rogers
Re: Deleting System Restore Point
You don't, the most you can do is run disk cleanup and use the advanced
options to remove all but the most recent one.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Jimbo" <Jimbo@discussions.microsoft.com> wrote in message
newsDE900CE-20BD-4BE8-AC68-C9B7AA09D118@microsoft.com...
> not
Old 09-18-2006   #3 (permalink)
Rock
> not
Same as in XP, you can't delete individual restore points and have it work.
You can delete either all or all but the last one.
Rock [MVP Windows Shell/User]
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore error (create restore point), event ID: 8193 Vista General
System Restore Not Saving Restore Point Vista General
System Restore Point very slow... Vista file management
System restore hasn't held a restore point since I installed Vista Vista General
