| | Iexplore AppHangB1 HELP??? I can not get iexplorer to start at all, so i cant make any updates of windows or find a solution online. I am now borrowing a computer to see if i can download something and send to my email and fix the problem that way. I would appreciate all help i can get. App Hand B1 iexplore.exe signature 1d64 type of stop 1 Bucket ID 305552894 Programversion 7.0.6000.167111 |
| home premium vista (64bit) | Re: Iexplore AppHangB1 HELP??? not sure if this will help but did you try system restore? if you can get into it and restore you system back to before it started. scrooge |
| | Re: Iexplore AppHangB1 HELP??? Im a computerilliterate,, so how do i do a system restore??? "scrooge" wrote: Quote: > > not sure if this will help but did you try system restore? > if you can get into it and restore you system back to before it > started. > scrooge > > > -- > scrooge > |
| | Re: Iexplore AppHangB1 HELP??? press windows key, in the search box type restore press enter on the left choose the top option, something like "Repair windows from system restore" choose a date that ur computer last worked fine, documents and such like u have done since will still remain, just settings files/programs get back to how they were hope that helped "milla" <milla@xxxxxx> wrote in message news:73381E48-A2F6-4DE2-9B2C-EC978AF00001@xxxxxx Quote: > Im a computerilliterate,, so how do i do a system restore??? > > > "scrooge" wrote: > Quote: >> >> not sure if this will help but did you try system restore? >> if you can get into it and restore you system back to before it >> started. >> scrooge >> >> >> -- >> scrooge >> -- Q9450 OC'd 3.8GHz 4x 2GB 1066Mhz RAM 1:1 9800GX2 1GB OC'd 680core/1060mem 1TB SpinPoint HDD 350GB secondary HDD 2x 22" HP w2207h TrackIR G15 keyboard Logitech G9 Laser Mouse MS ForceFeedBack 2 Joystick |
| home premium vista (64bit) | Re: Iexplore AppHangB1 HELP??? click your start button. then goto all programs and then Accessories then system tools then click on system restore. scrooge |
| WLM Not Responding (ApphangB1) | Live Messenger | |||
| AppHangB1 | Live Messenger | |||
| AppHangB1 FarCry2/COH crash | Gaming | |||
| Re: AppHangB1 | Live Messenger | |||
| AppHangB1 Error | Vista file management | |||
