| | Vista - Logon Sound |
| 09-16-2006 | #11 |
| | Re: Logon Sound I followed your instructions Tom - all went well until I got to "SAVE": ''already exists, replace?" YES "old sizeofimage and new sizeofimage are not equal - update sizeofimage?" YES "cannot create new image file - the original file has been probably packed" I ran the program normally and as Administrator - same results I saved it under a different name - copied it to System32 folder - tried to rename it to ''auithui'' - couldn't tried to delete the original auithui file - couldn't Thanks for you help - I must be missing something here BChat "Tom Ziegmann" <tziegmann@msn.com> wrote in message news:e4dISpg2GHA.600@TK2MSFTNGP05.phx.gbl... > The sound can be disabled. > > To disable the sound follow these steps. > > 1.Download PE Explorer from http://www.pe-explorer.com > 2. Open PE Explorer and open %windir%\system32\authui.dll > 3. Then go to View -> Resources > 4. Then Highlight WAVE and Press Delete > 5. Save the file and then click yes if you want it to update the Image > Size > > -- > Tom Ziegmann > Microsoft Certified Professional > Windows Vista / Server Longhorn TechBeta Tester > Windows Server 2003 SP2 TechBeta Tester > "BChat" <BChat@Smile.net> wrote in message > news:uSLpxUg2GHA.4648@TK2MSFTNGP04.phx.gbl... >> That doesn't work with the logon sound - at least not on my machine >> >> >> "compucv621" <compucv621@dejazzd.com> wrote in message >> news:2E8AF33B-01CE-484C-99D1-82ED15220AE9@microsoft.com... >>> well...are you trying to delete the file or just turn it off????if you >>> goto the sound icon on the system tray , aight click it, and then goto >>> sounds, find the sound option. then scroll to the windows logon thing >>> and click on where it says 'Windows Logon Sound.wav' and scroll to >>> '(None)' then click apply and ok. >>> >>> "BChat" <BChat@Smile.net> wrote in message >>> news:uv4Xzyf2GHA.1256@TK2MSFTNGP04.phx.gbl... >>>> Has anybody figured out how to silence the "logon" sound? It was >>>> discussed about two weeks and no solutions posted. Somebody, I hope, >>>> has figured it out since...........................................not >>>> the biggest issue facing the free world, but annoying just the same. >>> >> > |
| My System Specs |
| 09-17-2006 | #12 |
| | Re: Logon Sound According to the Microsoft Blogs this might be hard coded for 'branding' like the Apple start up sounds. Would be a real PITA if this is not removeable!! <DIV>"BChat" <BChat@Smile.net> wrote in message news:uv4Xzyf2GHA.1256@TK2MSFTNGP04.phx.gbl...</DIV>> Has anybody figured out how to silence the "logon" sound? It was discussed > about two weeks and no solutions posted. Somebody, I hope, has figured it > out since...........................................not the biggest issue > facing the free world, but annoying just the same. |
| My System Specs |
| 09-17-2006 | #13 |
| | Re: Logon Sound If you can find out the wav file that is being called (hopefully) you can use another program (dual booting - DOS - Recovery Console from XP, etc) to replace the file with either an empty wav file or one of the more beniegn files, like a click (renaming to the called wav file) "BChat" <BChat@Smile.net> wrote in message news:e9HSiGh2GHA.4756@TK2MSFTNGP04.phx.gbl... >I followed your instructions Tom - all went well until I got to "SAVE": > ''already exists, replace?" YES > "old sizeofimage and new sizeofimage are not equal - update sizeofimage?" > YES > "cannot create new image file - the original file has been probably > packed" > > I ran the program normally and as Administrator - same results > > I saved it under a different name - copied it to System32 folder - tried > to rename it to ''auithui'' - couldn't > tried to delete the original auithui file - couldn't > > Thanks for you help - I must be missing something here > > BChat > > > > "Tom Ziegmann" <tziegmann@msn.com> wrote in message > news:e4dISpg2GHA.600@TK2MSFTNGP05.phx.gbl... >> The sound can be disabled. >> >> To disable the sound follow these steps. >> >> 1.Download PE Explorer from http://www.pe-explorer.com >> 2. Open PE Explorer and open %windir%\system32\authui.dll >> 3. Then go to View -> Resources >> 4. Then Highlight WAVE and Press Delete >> 5. Save the file and then click yes if you want it to update the Image >> Size >> >> -- >> Tom Ziegmann >> Microsoft Certified Professional >> Windows Vista / Server Longhorn TechBeta Tester >> Windows Server 2003 SP2 TechBeta Tester >> "BChat" <BChat@Smile.net> wrote in message >> news:uSLpxUg2GHA.4648@TK2MSFTNGP04.phx.gbl... >>> That doesn't work with the logon sound - at least not on my machine >>> >>> >>> "compucv621" <compucv621@dejazzd.com> wrote in message >>> news:2E8AF33B-01CE-484C-99D1-82ED15220AE9@microsoft.com... >>>> well...are you trying to delete the file or just turn it off????if you >>>> goto the sound icon on the system tray , aight click it, and then goto >>>> sounds, find the sound option. then scroll to the windows logon thing >>>> and click on where it says 'Windows Logon Sound.wav' and scroll to >>>> '(None)' then click apply and ok. >>>> >>>> "BChat" <BChat@Smile.net> wrote in message >>>> news:uv4Xzyf2GHA.1256@TK2MSFTNGP04.phx.gbl... >>>>> Has anybody figured out how to silence the "logon" sound? It was >>>>> discussed about two weeks and no solutions posted. Somebody, I hope, >>>>> has figured it out since...........................................not >>>>> the biggest issue facing the free world, but annoying just the same. >>>> >>> >> > |
| My System Specs |
| 09-17-2006 | #14 |
| | Re: Logon Sound John, I tried to delete, rename, replace, (and anything else I could think of) the wave within the DLL. I think it could have been replaced with the ''paid'' version of PE Explorer. The trial version I downloaded wouldn't do it. I quit (for now). I would hope M/S would take another look at the idea of having the sound undeletable - it goes against my theory of "my machine my way". "John Barnes" <jbarnes@email.net> wrote in message news:%230ajekn2GHA.1568@TK2MSFTNGP03.phx.gbl... > If you can find out the wav file that is being called (hopefully) you can > use another program (dual booting - DOS - Recovery Console from XP, etc) > to replace the file with either an empty wav file or one of the more > beniegn files, like a click (renaming to the called wav file) > > "BChat" <BChat@Smile.net> wrote in message > news:e9HSiGh2GHA.4756@TK2MSFTNGP04.phx.gbl... >>I followed your instructions Tom - all went well until I got to "SAVE": >> ''already exists, replace?" YES >> "old sizeofimage and new sizeofimage are not equal - update sizeofimage?" >> YES >> "cannot create new image file - the original file has been probably >> packed" >> >> I ran the program normally and as Administrator - same results >> >> I saved it under a different name - copied it to System32 folder - tried >> to rename it to ''auithui'' - couldn't >> tried to delete the original auithui file - couldn't >> >> Thanks for you help - I must be missing something here >> >> BChat >> >> >> >> "Tom Ziegmann" <tziegmann@msn.com> wrote in message >> news:e4dISpg2GHA.600@TK2MSFTNGP05.phx.gbl... >>> The sound can be disabled. >>> >>> To disable the sound follow these steps. >>> >>> 1.Download PE Explorer from http://www.pe-explorer.com >>> 2. Open PE Explorer and open %windir%\system32\authui.dll >>> 3. Then go to View -> Resources >>> 4. Then Highlight WAVE and Press Delete >>> 5. Save the file and then click yes if you want it to update the Image >>> Size >>> >>> -- >>> Tom Ziegmann >>> Microsoft Certified Professional >>> Windows Vista / Server Longhorn TechBeta Tester >>> Windows Server 2003 SP2 TechBeta Tester >>> "BChat" <BChat@Smile.net> wrote in message >>> news:uSLpxUg2GHA.4648@TK2MSFTNGP04.phx.gbl... >>>> That doesn't work with the logon sound - at least not on my machine >>>> >>>> >>>> "compucv621" <compucv621@dejazzd.com> wrote in message >>>> news:2E8AF33B-01CE-484C-99D1-82ED15220AE9@microsoft.com... >>>>> well...are you trying to delete the file or just turn it off????if you >>>>> goto the sound icon on the system tray , aight click it, and then goto >>>>> sounds, find the sound option. then scroll to the windows logon thing >>>>> and click on where it says 'Windows Logon Sound.wav' and scroll to >>>>> '(None)' then click apply and ok. >>>>> >>>>> "BChat" <BChat@Smile.net> wrote in message >>>>> news:uv4Xzyf2GHA.1256@TK2MSFTNGP04.phx.gbl... >>>>>> Has anybody figured out how to silence the "logon" sound? It was >>>>>> discussed about two weeks and no solutions posted. Somebody, I hope, >>>>>> has figured it out >>>>>> since...........................................not the biggest issue >>>>>> facing the free world, but annoying just the same. >>>>> >>>> >>> >> > > |
| My System Specs |
| 09-17-2006 | #15 |
| | Re: Logon Sound On Sun, 17 Sep 2006 14:44:59 -0400, "BChat" <BChat@Smile.net> wrote: >John, > >I tried to delete, rename, replace, (and anything else I could think of) the >wave within the DLL. I think it could have been replaced with the ''paid'' >version of PE Explorer. The trial version I downloaded wouldn't do it. I >quit (for now). > >I would hope M/S would take another look at the idea of having the sound >undeletable - it goes against my theory of "my machine my way". What I did was to use a freeware program called Resource Hacker. Move the authui.dll to a temp location, open it with ResHack and delete the Wave resource, then save it. Rename the original authui.dll to authui.bak just in case. Move the edited authui.dll back into system32. I did this from my XP side of my dual boot. UAC was already disabled on Vista. -- Michael Cecil http://home.comcast.net/~macecil/ http://home.comcast.net/~safehex/ http://home.comcast.net/~macecil/hackingvista/ |
| My System Specs |
| 09-17-2006 | #16 |
| | Re: Logon Sound Michael, Thanks for reply. I cannot move, delete, or do anything to the file except copy it to another location - so I did. I was able to remove the wave resource using ResHack, but I cannot move or copy the modified file back into System 32. I do have UAC turned off. I tired doing this from XP and from within Vista. For some reason I am not allowed to do it. So far I am 0 for 2 with this operation. Thanks again "Michael Cecil" <macecil@gmail.com> wrote in message news:P9qdnTNqJfFqRZDYnZ2dnUVZ_s-dnZ2d@comcast.com... On Sun, 17 Sep 2006 14:44:59 -0400, "BChat" <BChat@Smile.net> wrote: >John, > >I tried to delete, rename, replace, (and anything else I could think of) >the >wave within the DLL. I think it could have been replaced with the ''paid'' >version of PE Explorer. The trial version I downloaded wouldn't do it. I >quit (for now). > >I would hope M/S would take another look at the idea of having the sound >undeletable - it goes against my theory of "my machine my way". What I did was to use a freeware program called Resource Hacker. Move the authui.dll to a temp location, open it with ResHack and delete the Wave resource, then save it. Rename the original authui.dll to authui.bak just in case. Move the edited authui.dll back into system32. I did this from my XP side of my dual boot. UAC was already disabled on Vista. -- Michael Cecil http://home.comcast.net/~macecil/ http://home.comcast.net/~safehex/ http://home.comcast.net/~macecil/hackingvista/ |
| My System Specs |
| 09-17-2006 | #17 |
| | Re: Logon Sound On Sun, 17 Sep 2006 21:19:24 -0400, "BChat" <not@available.com> wrote: >Michael, > >Thanks for reply. I cannot move, delete, or do anything to the file except >copy it to another location - so I did. I was able to remove the wave >resource using ResHack, but I cannot move or copy the modified file back >into System 32. I do have UAC turned off. I tired doing this from XP and >from within Vista. For some reason I am not allowed to do it. > >So far I am 0 for 2 with this operation. Thanks again Well, I didn't find it necessary but maybe that's because I was logged into XP with admin rights when I moved the file back. Try logging into XP with admin rights and if you still can't replace the file you could always just take ownership of it first. -- Michael Cecil http://home.comcast.net/~macecil/ http://home.comcast.net/~safehex/ http://home.comcast.net/~macecil/hackingvista/ |
| My System Specs |
| 09-18-2006 | #18 |
| | Re: Logon Sound Michael, The ''ownership'' thing worked - you are my new hero! As frustrating as this whole deal has been, I learned some things, and that makes it all worth it. Thank you again for your patience and assistance. My computer thanks you too - you saved its life ;o) A silent re-boot..........................................................I love it. "Michael Cecil" <macecil@gmail.com> wrote in message news:a_ednQQ9I_3ojJPYnZ2dnUVZ_tidnZ2d@comcast.com... > On Sun, 17 Sep 2006 21:19:24 -0400, "BChat" <not@available.com> wrote: > >>Michael, >> >>Thanks for reply. I cannot move, delete, or do anything to the file except >>copy it to another location - so I did. I was able to remove the wave >>resource using ResHack, but I cannot move or copy the modified file back >>into System 32. I do have UAC turned off. I tired doing this from XP and >>from within Vista. For some reason I am not allowed to do it. >> >>So far I am 0 for 2 with this operation. Thanks again > > Well, I didn't find it necessary but maybe that's because I was logged > into XP with admin rights when I moved the file back. Try logging into XP > with admin rights and if you still can't replace the file you could always > just take ownership of it first. > -- > Michael Cecil > http://home.comcast.net/~macecil/ > http://home.comcast.net/~safehex/ > http://home.comcast.net/~macecil/hackingvista/ |
| My System Specs |
| Similar Threads for: Logon Sound | ||||
| Services Fail with Error Logon failure: the user has not been granted the requested logon type at this computer. | Server General | |||
| Logon Failure: the user has not granted the requested logon type at this | Vista networking & sharing | |||
| Logon failure: the user has not been granted the requested logon typeat this computer. | .NET General | |||
| Windows Startup Sound and Windows Logon Sound Collide | Vista General | |||
| Logon/Startup sound | Vista General | |||
