Vista - Epson c88+ problem with Vista
Old 08-20-2008   #1 (permalink)
FireBrick
vista home premium OS
My Epson C88+ doesn't want to work correctly.
I can install it, but it won't print.
It's a USB connection
Sometimes it prints a page but misses most of the text.
Sometimes it justs burps a line feed or two and then sits.
Can't seem to find the right driver or way to configure.
It worked perfectly on my XP OS
I have two computers connected in a lan via a router, the printer was marked
to share.
Problem with Epson EPL5700 on Vista SP1 Vista print fax & scan
Epson 1200U problem in Vista Ultimate Vista hardware & devices
Epson Vista twain driver problem Vista print fax & scan
Epson projector problem with vista Vista hardware & devices
