| | Vista - Long Beep After Startup, please help |
| 08-21-2008 | #1 (permalink) |
| | Long Beep After Startup, please help Hello, this is my first post here. This forum is nice! Anyway, i have a Motherboard Asus P5KC with integrated audio (Realtek) - Vista Home Premium. So last night i connected my bass to the mic input but i believe the signal was too strong because the sound was clipping bad. So when i played a little harder, suddenly the pc started to make a continuous beep sound. Anyway, i figured that out, for some reason the PC Beep option was all the way up! (Right Click on the Realtek icon on the taskbar -> Sound -> Speakers -> Properties -> Levels -> PC Beep). So i turned PC beep to 0 and then hit the mute icon next to the bar as well. So that took care of the constant beeping. However, i get a loud continuous beep (same pitch) that lasts around 6 seconds everytime i start my pc. The beep occurs at the end of the hourglass screen, just before it plays the Windows Startup sound. It is really annoying and loud. I have tried everything. Uninstall the realtek drivers from device manager and programs. Then reinstall them. Also i have tried disabling the audio device from the bios then uninstalling drivers, then re-enabling it and reinstalling drivers but nothing. I have also tried to turn off the beep from regedit (i saw it in another thread) and i have also tried to stop the beep from the device manager -> show hidden devices -> non Plug n play devices -> Beep -> Startup = disabled. But nothing worked. And it is driving me crazy! Could it be that my sound circuit now has a problem or is it something fixable? Please i need your help. -- ACHIEVEIT ------------------------------------------------------------------------ ACHIEVEIT's Profile: http://winvistaclub.com/forum/member.php?userid=356 View this thread: http://winvistaclub.com/forum/showthread.php?t=20253 |
| My System Specs |
| 08-21-2008 | #2 (permalink) |
| | Re: Long Beep After Startup, please help Oh, i forgot to mention, everything works fine though, i mean all sounds are played the way they were meant to. Only that beep is wrong. Everything else works fine. -- ACHIEVEIT ------------------------------------------------------------------------ ACHIEVEIT's Profile: http://winvistaclub.com/forum/member.php?userid=356 View this thread: http://winvistaclub.com/forum/showthread.php?t=20253 |
| My System Specs |
| 08-21-2008 | #3 (permalink) |
| | Re: Long Beep After Startup, please help Hm, i never thought of that. I'll give it a try now. What will be lost? -- ACHIEVEIT ------------------------------------------------------------------------ ACHIEVEIT's Profile: http://winvistaclub.com/forum/member.php?userid=356 View this thread: http://winvistaclub.com/forum/showthread.php?t=20253 |
| My System Specs |
| 08-22-2008 | #4 (permalink) |
| | Re: Long Beep After Startup, please help Hello again, problem _not_ solved by removing the battery. Any other ideas? -- ACHIEVEIT ------------------------------------------------------------------------ ACHIEVEIT's Profile: http://winvistaclub.com/forum/member.php?userid=356 View this thread: http://winvistaclub.com/forum/showthread.php?t=20253 |
| My System Specs |
| 08-22-2008 | #5 (permalink) |
| | Re: Long Beep After Startup, please help Paul Montgomery;90091 Wrote: Quote: > On Fri, 22 Aug 2008 19:52:54 +0530, ACHIEVEIT > <ACHIEVEIT.3ejtal@xxxxxx> wrote: > Quote: > >Hello again, problem _not_ solved by removing the battery. Any other > >ideas? > For those out here (not using that web-interface) and who don't have a > photographic memory, would you please hit the quote button before > replying? -- ACHIEVEIT ------------------------------------------------------------------------ ACHIEVEIT's Profile: http://winvistaclub.com/forum/member.php?userid=356 View this thread: http://winvistaclub.com/forum/showthread.php?t=20253 |
| My System Specs |
| 08-22-2008 | #6 (permalink) |
| | Re: Long Beep After Startup, please help Paul Montgomery;90193 Wrote: Quote: > On Fri, 22 Aug 2008 22:37:55 +0530, ACHIEVEIT > <ACHIEVEIT.3ek0r1@xxxxxx> wrote: > Quote: > > > >Paul Montgomery;90091 Wrote: Quote: > >> On Fri, 22 Aug 2008 19:52:54 +0530, ACHIEVEIT > >> <ACHIEVEIT.3ejtal@xxxxxx> wrote: > >> > >> >Hello again, problem _not_ solved by removing the battery. Any Quote: Quote: > >> >ideas? > >> > >> For those out here (not using that web-interface) and who don't have Quote: Quote: > >> photographic memory, would you please hit the quote button before > >> replying? > >Done. Anything on the subject? > Don't know if it will help (I had to go to Google Groups to get whole > thread). > > You wrote: > Quote: > > So last night i connected my bass to the mic input but i > > believe the signal was too strong because the sound was > > clipping bad. So when i played a little harder, suddenly > > the pc started to make a continuous beep sound. > Your problem is somehow related to the above, it's not a > Windows problem. And it's not a BIOS problem as one > of the Vista trolls suggested or the "beep" would sound > at POST. > Quote: > > Anyway, i figured that out, for some reason the PC Beep > > option was all the way up! (Right Click on the Realtek > > icon on the taskbar -> Sound -> Speakers -> Properties -> > > Levels -> PC Beep). So i turned PC beep to 0 and then hit the > > mute icon next to the bar as well. So that took care of the > > constant beeping. > No... it merely turned off the sound. It did nothing to > fix whatever it was that you did when you played your bass > "a little harder." > Quote: > > However, i get a loud continuous beep (same pitch) that > > lasts around 6 seconds everytime i start my pc. > Are you sure the PC speaker is disabled? To make sure, disconnect > your regular speakers before restarting. > > If there is no sound after doing that, reconnect your speakers and > disconnect everything else from the sound card and restart. in fact are the ones integrated in the screen - just stereo speakers) and restarted. 2 secs after i turned it on there was the usual low-volume short beep from the pc speaker showing my hardware is ok. So windows load normal and no beep as expected since the speakers were disconnected. Then i reconnected them, all sounds ok, restarted and there was that awful sound again. I don't really mess with that but could it be something with the registry? An option that wouldn't change although i uninstalled the drivers? Thanks -- ACHIEVEIT ------------------------------------------------------------------------ ACHIEVEIT's Profile: http://winvistaclub.com/forum/member.php?userid=356 View this thread: http://winvistaclub.com/forum/showthread.php?t=20253 |
| My System Specs |
| 08-22-2008 | #7 (permalink) |
| | Re: Long Beep After Startup, please help Paul Montgomery;90265 Wrote: Quote: > On Sat, 23 Aug 2008 04:35:42 +0530, ACHIEVEIT > <ACHIEVEIT.3ekhhp@xxxxxx> wrote: > Quote: > > > >Paul Montgomery;90193 Wrote: Quote: > >> On Fri, 22 Aug 2008 22:37:55 +0530, ACHIEVEIT > >> <ACHIEVEIT.3ek0r1@xxxxxx> wrote: > >> > >> > > >> >Paul Montgomery;90091 Wrote: > >> >> On Fri, 22 Aug 2008 19:52:54 +0530, ACHIEVEIT > >> >> <ACHIEVEIT.3ejtal@xxxxxx> wrote: > >> >> > >> >> >Hello again, problem _not_ solved by removing the battery. Any > >> other > >> >> >ideas? > >> >> > >> >> For those out here (not using that web-interface) and who don't Quote: Quote: > >> a > >> >> photographic memory, would you please hit the quote button Quote: Quote: > >> >> replying? > >> > > >> >Done. Anything on the subject? > >> > >> Don't know if it will help (I had to go to Google Groups to get Quote: Quote: > >> thread). > >> > >> You wrote: > >> > >> > So last night i connected my bass to the mic input but i > >> > believe the signal was too strong because the sound was > >> > clipping bad. So when i played a little harder, suddenly > >> > the pc started to make a continuous beep sound. > >> > >> Your problem is somehow related to the above, it's not a > >> Windows problem. And it's not a BIOS problem as one > >> of the Vista trolls suggested or the "beep" would sound > >> at POST. > >> > >> > Anyway, i figured that out, for some reason the PC Beep > >> > option was all the way up! (Right Click on the Realtek > >> > icon on the taskbar -> Sound -> Speakers -> Properties -> > >> > Levels -> PC Beep). So i turned PC beep to 0 and then hit the > >> > mute icon next to the bar as well. So that took care of the > >> > constant beeping. > >> > >> No... it merely turned off the sound. It did nothing to > >> fix whatever it was that you did when you played your bass > >> "a little harder." > >> > >> > However, i get a loud continuous beep (same pitch) that > >> > lasts around 6 seconds everytime i start my pc. > >> > >> Are you sure the PC speaker is disabled? To make sure, disconnect > >> your regular speakers before restarting. > >> > >> If there is no sound after doing that, reconnect your speakers and > >> disconnect everything else from the sound card and restart. > >Hi, thanks for your reply. So, i disconnected the speakers (my Quote: > >in fact are the ones integrated in the screen - just stereo speakers) > >and restarted. 2 secs after i turned it on there was the usual > >low-volume short beep from the pc speaker showing my hardware is ok. Quote: > >windows load normal and no beep as expected since the speakers were > >disconnected. Then i reconnected them, all sounds ok, restarted and > >there was that awful sound again. I don't really mess with that but > >could it be something with the registry? An option that wouldn't Quote: > >although i uninstalled the drivers? Thanks > Note that I also said: > Quote: Quote: > >> If there is no sound after doing that, reconnect your speakers and > >> disconnect everything else from the sound card and restart. > Did you do that? My friend Paul, i guess pc's are beyond my comprehension although i study electrical engineering. I thought why not try to download new drivers from the realtek site? Although when i did this trough Driver Update in windows it showed they are up to date. So i downloaded the drivers (there was a warning that the drivers were general purpose and that you should check your motherboard company's site to find the newest for your occasion). So i checked asus and the drivers there were even older than the ones in the cd that came with the motherboard..go figure. Anyway i downloaded them installed them and everything is fine now. I have PC beep option all the way up and no beep is coming through the speakers. I took a minute to think what you said. PC beep was something different than i had in mind. By turning it to 0 i just covered the problem. That's why it would beep at startup - it hadn't loaded my profile yet that had the pc beep off. The tragedy is that the drivers that were in the cd and that worked just fine until before "the incident" wouldn't work right no matter how many uninstalls and deletes i did. I don't get it really. Anyway, now it works and i will stop experimenting so much. I hope that helps anyone else in the future. I really appreciate your and Yan's time and efforts to help. See ya. -- ACHIEVEIT ------------------------------------------------------------------------ ACHIEVEIT's Profile: http://winvistaclub.com/forum/member.php?userid=356 View this thread: http://winvistaclub.com/forum/showthread.php?t=20253 |
| My System Specs |
| Similar Threads for: Long Beep After Startup, please help | ||||
Startup Beep | General Discussion | |||
| PC doesn't beep on startup | General Discussion | |||
| RE: Really long startup | Vista General | |||
| Re: Really long startup | Vista General | |||
