Vista - RE: USB.Mass storage device
Old 08-22-2008   #1 (permalink)
N1K
You should change the drive letter in disk management..
Right click on my computer-->manage-->disk management, locate your disk and
change its drive letter. The system probably assigned a drive letter for it
which was already in use..
MCSA, MCDST, MCP, MCTS, MCITP
http://www.wincert.net
"Sameul" wrote:
Quote:
> When the mass storage device, such as portable disk (the size is from 1 GB
> to 40 GB), was plugged into USB port, the VISTA system shows everything is
> OK, even the icon "Safely Remove Hardware" is appeared at the right-bottom
> area.
> But in MY COMPUTER, there is no the disk drive for clicking after
> refreshing. Is there someone know the reason?
> Sameul
usb mass storage device problem Vista hardware & devices
USB Mass Storage Device Driver Vista hardware & devices
USB Mass Storage Device Vista hardware & devices
Mass Storage Device Vista performance & maintenance
Mass storage device Vista hardware & devices
