Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
0.0.0.0 default gateway problem
LinkBack Thread Tools Display Modes
Old 08-22-2008   #1 (permalink)
Shamrock17
Guest
Windows vista ultimate on Dell Laptop.
Unable to get rid of 0.0.0.0 default gateway entry. Nothing shows on the
network properties connection, Ipconfig/release does nothing... not sure how
to resolve.
MN
Old 08-22-2008   #2 (permalink)
Mark L. Ferguson
Guest
Re: 0.0.0.0 default gateway problem
The default gateway is your router address, if you use one. I would reset
the power on the router. Also, check the network cables and connectors.
Please use the Communities guidelines when posting.
http://www.microsoft.com/wn3/locales...help_en-us.htm
Use the "Ratings" feature. It helps the new users.
Mark L. Ferguson MS-MVP
https://mvp.support.microsoft.com/profile/Mark.Ferguson
"Shamrock17" <Shamrock17@xxxxxx> wrote in message
news68EE691-C87B-45EB-89A6-2E5607051E80@xxxxxx
> how
> to resolve.
> MN
Old 08-22-2008   #3 (permalink)
Not Me
Guest
Has it ever worked?
I would start by making sure the cable to the router or the wireless adapter
is working/enabled/connected properly.
My laptop has a switch on the side to turn wireless on/off.
If using a CAT5, try a different cable.
If still no connection, remove the network adapter from device manager and
let Vista detect it & reinstall the driver.
Make sure the LAN connection is set to get an IP automatically and the
router is set to assign an IP automatically (DHCP enabled and enough
addresses available for the number of machines you have connected to it).
If still no joy, maybe scan for malware...call the manufacturer if still
under warranty...
A Professional Amateur...If anyone knew it all, none of would be here!
CarGodZeroOne@xxxxxx
Change Alpha to Numeric to reply
> how
> to resolve.
> MN
Old 08-23-2008   #4 (permalink)
Vista Ultimate x32
I've seen this one on a few machines, in fact one of mine does it intermittently.
An ipconfig/all shows it to have the gateway address of the router AS WELL as the 0.0.0.0 entry
Still researching the cause but I have found you can right-click "diagnose" the Local area connection that has the problem and then choose "Reset the network adapter .... " it will remove the 0.0.0.0 entry and leave you with the valid GW address again.
Hope that helps your situation
Display Modes
Default gateway problem Tedium Vista networking & sharing 1 06-05-2008 09:44 PM
Vista VPN Default gateway problem Ahmad Sabry Vista General 0 05-24-2008 04:14 AM
Default Gateway xfix Vista networking & sharing 1 04-14-2008 08:58 PM
Problem to get default gateway in dhcp Max Vista networking & sharing 5 10-05-2007 07:11 AM
Changing the default Gateway in PS Doc PowerShell 1 05-03-2007 01:47 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
