| | Own post not visible in this ng Last evening, Aug. 22, I posted a question in this ng under subject "Strange icon behavior". It's not showing up in the ng, at least to me. I know it went thru because when I google the keywords I see the post in Vista Forums. Any clues? Thanks. George |
| | Re: Own post not visible in this ng This post showed up. Strange!? George "George" <null@xxxxxx> wrote in message news:uDnrBDVBJHA.4132@xxxxxx Quote: > Last evening, Aug. 22, I posted a question in this ng under subject > "Strange icon behavior". It's not showing up in the ng, at least to me. > I know it went thru because when I google the keywords I see the post in > Vista Forums. > > Any clues? Thanks. > > George |
| | Re: Own post not visible in this ng There are problems if the 'use newsgroup communities support feature' is enabled in Windows Mails option. Microsoft are currently looking into this. If you still have problems then remove the check mark from the 'use newsgroup communities support feature on the General tab of options. -- -- John Barnett MVP Associate Expert Windows Desktop Experience Web: http://xphelpandsupport.mvps.org Web: http://vistasupport.mvps.org The information in this mail/post is supplied "as is". No warranty of any kind, either expressed or implied, is made in relation to the accuracy, reliability or content of this mail/post. The Author shall not be liable for any direct, indirect, incidental or consequential damages arising out of the use of, or inability to use, information or opinions expressed in this mail/post.. "George" <null@xxxxxx> wrote in message news:uDnrBDVBJHA.4132@xxxxxx Quote: > Last evening, Aug. 22, I posted a question in this ng under subject > "Strange icon behavior". It's not showing up in the ng, at least to me. > I know it went thru because when I google the keywords I see the post in > Vista Forums. > > Any clues? Thanks. > > George |
| | Re: Own post not visible in this ng John, thanks for the prompt reply, but I don't have "use newsgroup communities support feature" on the General tab, or on any of the other tabs. ?? George "John Barnett MVP" <freelance@xxxxxx> wrote in message news:ezzeuJVBJHA.1224@xxxxxx Quote: > There are problems if the 'use newsgroup communities support feature' is > enabled in Windows Mails option. Microsoft are currently looking into > this. If you still have problems then remove the check mark from the 'use > newsgroup communities support feature on the General tab of options. > > -- > > -- > John Barnett MVP > Associate Expert > Windows Desktop Experience > > Web: http://xphelpandsupport.mvps.org > Web: http://vistasupport.mvps.org > > The information in this mail/post is supplied "as is". No warranty of any > kind, either expressed or implied, is made in relation to the accuracy, > reliability or content of this mail/post. The Author shall not be liable > for > any direct, indirect, incidental or consequential damages arising out of > the > use of, or inability to use, information or opinions expressed in this > mail/post.. > > > "George" <null@xxxxxx> wrote in message > news:uDnrBDVBJHA.4132@xxxxxx Quote: >> Last evening, Aug. 22, I posted a question in this ng under subject >> "Strange icon behavior". It's not showing up in the ng, at least to me. >> I know it went thru because when I google the keywords I see the post in >> Vista Forums. >> >> Any clues? Thanks. >> >> George |
| | Re: Own post not visible in this ng My apologies, George, Paul is correct I am using Windows Live Mail; however, did add your newsgroups via the Windows Communities option in the left hand pane of Windows Mail? If so the reason I gave in my last post may still apply. -- -- John Barnett MVP Associate Expert Windows Desktop Experience Web: http://xphelpandsupport.mvps.org Web: http://vistasupport.mvps.org The information in this mail/post is supplied "as is". No warranty of any kind, either expressed or implied, is made in relation to the accuracy, reliability or content of this mail/post. The Author shall not be liable for any direct, indirect, incidental or consequential damages arising out of the use of, or inability to use, information or opinions expressed in this mail/post.. "George" <null@xxxxxx> wrote in message news:ecdMcUVBJHA.3348@xxxxxx Quote: > John, thanks for the prompt reply, but I don't have "use newsgroup > communities support feature" on the General tab, or on any of the other > tabs. > > ?? > > George > > > "John Barnett MVP" <freelance@xxxxxx> wrote in message > news:ezzeuJVBJHA.1224@xxxxxx Quote: >> There are problems if the 'use newsgroup communities support feature' is >> enabled in Windows Mails option. Microsoft are currently looking into >> this. If you still have problems then remove the check mark from the 'use >> newsgroup communities support feature on the General tab of options. >> >> -- >> >> -- >> John Barnett MVP >> Associate Expert >> Windows Desktop Experience >> >> Web: http://xphelpandsupport.mvps.org >> Web: http://vistasupport.mvps.org >> >> The information in this mail/post is supplied "as is". No warranty of any >> kind, either expressed or implied, is made in relation to the accuracy, >> reliability or content of this mail/post. The Author shall not be liable >> for >> any direct, indirect, incidental or consequential damages arising out of >> the >> use of, or inability to use, information or opinions expressed in this >> mail/post.. >> >> >> "George" <null@xxxxxx> wrote in message >> news:uDnrBDVBJHA.4132@xxxxxx Quote: >>> Last evening, Aug. 22, I posted a question in this ng under subject >>> "Strange icon behavior". It's not showing up in the ng, at least to me. >>> I know it went thru because when I google the keywords I see the post in >>> Vista Forums. >>> >>> Any clues? Thanks. >>> >>> George |
| Visible Fonts | Live Mail | |||
| selected row visible | .NET General | |||
| Messenger not visible | Live Messenger | |||
| Computer isn't visible | Vista networking & sharing | |||
| website not visible | Vista General | |||
