Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
br> br> |
| | Thread Tools | Display Modes |
| Newbie Rep Power: 2 ![]() | Rootkit help PLEASE!!! Ok so it started with a pop up saying that I will no longer received updates from windows security and that my version of vista is not genuine. Dell has check the system and it is genuine. I downloaded avast and this is the what it said: suspicious malware: c:/windows/system32/kdila.exe.rootkit:hiddenfile. ccrtklum.dll Can anyone please tell me how to get rid of this? I am unable to uninstall spysweeper or download the updated version of mcafee because of this. Any help would be greatly appreciated. |
| Guest | Re: Rootkit help PLEASE!!! F-Secure BlackLight (Download Trial) http://www.f-secure.com/blacklight/ Microsoft Malicious Software Removal Tool The Microsoft Windows Malicious Software Removal Tool helps remove specivic, prevalent malicious software from computers that are running Windows Vista, Windows Server 2003, Windows XP, or Windows 2000. http://support.microsoft.com/kb/890830 Karl "gardnertj00" <guest@xxxxxx-email.com> wrote in message news:a005638094e192fafe10d602144765cb@xxxxxx-gateway.com... Ok so it started with a pop up saying that I will no longer received updates from windows security and that my version of vista is not genuine. Dell has check the system and it is genuine. I downloaded avast and this is the what it said: suspicious malware: c:/windows/system32/kdila.exe.rootkit:hiddenfile. ccrtklum.dll Can anyone please tell me how to get rid of this? I am unable to uninstall spysweeper or download the updated version of mcafee because of this. Any help would be greatly appreciated. -- gardnertj00 |
| | #3 (permalink) | ||||||||||||
| Guest | RE: Rootkit help PLEASE!!! Install and scan with Spybot Search & Destroy, and Malwarebytes. Scan in Safe Mode if necessary. All info below. http://www.spybot.info/en/index.html Spybot Search & Destroy 1.6 is a very good, FREE Anti-Spyware Program. Download, install, update, and immunize your System with it. Then SCAN with it. Update it, and scan your System once a fortnight. http://www.malwarebytes.org/mbam.php Malwarebytes is as the name says, a Malware Remover! For the Free version scroll down their page to either download from Download.com, or Major Geeks.com Download, install, and update. Important re: Safe Mode If you happen to find a problem that you can’t uninstall / delete, reboot the computer, and go into Safe Mode. To get into Safe mode, tap F8 right at Power On / Startup, and use UP arrow key to get to Safe Mode from list of options, then hit ENTER. RESCAN your computer with Avast(or your AV) and Spybot S & D while in Safe Mode -- Mick Murphy - Qld - Australia "gardnertj00" wrote:
My System Specs![]() | |||||||||||||
| | #4 (permalink) | ||||||||||||
| Guest | Re: Rootkit help PLEASE!!! Sometimes you can delete manually in safe mode. But usually it is better to scan with malware software in safe mode. Spybot search & destroy is my choice, but there are many. If it is indeed a rootkit, you might want to get one of the rootkit removal tools. I have used rootkitunhooker successfully. Google has several free versions. "gardnertj00" <guest@xxxxxx-email.com> wrote in message news:a005638094e192fafe10d602144765cb@xxxxxx-gateway.com...
| | #5 (permalink) | ||||||||||||
| Guest | Re: Rootkit help PLEASE!!! Microsoft's RootKit Revealer http://technet.microsoft.com/en-us/s.../bb897445.aspx "gardnertj00" <guest@xxxxxx-email.com> wrote in message news:a005638094e192fafe10d602144765cb@xxxxxx-gateway.com...
| | #6 (permalink) | ||||||||||||
| Guest | Re: Rootkit help PLEASE!!! On Tue, 26 Aug 2008 21:04:30 -0500, gardnertj00 wrote:
The effectiveness of an individual Rootkit removal application are wide-ranging and it is recommended utilizing a collection of detection/removal tools; You are encouraged to try all of them (join relevant fora for additional support i.e. interpretation of scan results): DarkSpy http://www.antirootkit.com/software/DarkSpy.htm http://www.antirootkit.com/forums/viewforum.php?f=18 F-Secure BlackLight (Download Trial) http://www.f-secure.com/blacklight/ http://www.antirootkit.com/forums/viewforum.php?f=13 GMER - is an application that detects and removes rootkits. http://www.gmer.net/index.php http://antirootkit.com/forums/index....81ffe4361c3a17 IceSword http://www.antirootkit.com/software/IceSword.htm http://www.antirootkit.com/forums/index.php RAIDE http://www.rootkit.com/project.php?id=33 download: http://www.rootkit.com/vault/petersi...IDE_BETA_1.zip http://www.rootkit.com/boardm.php Rootkit Revealer http://www.microsoft.com/technet/sys...tRevealer.mspx http://forum.sysinternals.com/forum_topics.asp?FID=15 RootKit Hook Analyzer http://www.softpedia.com/get/Securit...Analyzer.shtml http://www.antirootkit.com/forums/viewforum.php?f=17 RootKit Hook Analyzer http://www.resplendence.com/hookanalyzer http://www.antirootkit.com/forums/viewforum.php?f=17 RootAlyzer http://forums.spybot.info/showthread.php?t=24185 http://www.spybotupdates.com/files/rootalyz.zip Sophos Anti-Rootkit - Free tool for rootkit detection and removal http://www.sophos.com/products/free-...i-rootkit.html Direct link: http://www.sophos.com/support/cleaners/sarsfx.exe http://www.techsupportforum.com/netw...i-rootkit.html System Virginity Verifier http://www.softpedia.com/get/System/...Verifier.shtml http://www.antirootkit.com/forums/viewforum.php?f=25 System Virginity Verifier http://www.antirootkit.com/software/...y-Verifier.htm http://www.antirootkit.com/forums/viewforum.php?f=25 VICE http://www.rootkit.com/project.php?id=20 download: http://www.rootkit.com/vault/fuzen_op/vice.zip http://www.rootkit.com/boardm.php "Make sure you always read the current user instructions for your scanning tools to see what special steps you need to take before, during and after the clean-up process. Then, after you've found and cleaned a rootkit, rescan the system once you reboot to double-check that it was fully cleaned and the malware hasn't returned." Avoiding Rootkit Infection. "The rules to avoid rootkit infection are for the most part the same as avoiding any malware infection however there are some special considerations: Because rootkits meddle with the operating system itself they *require* full Administrator rights to install. Hence infection can be avoided by running Windows from an account with *lesser* privileges" (LUA in XP and UAC in Vista). AntiHook http://www.infoprocess.com.au/AntiHook.php DiamondCS ProcessGuard http://www.diamondcs.com.au/processguard/ http://www.diamondcs.com.au/processguard/download.php Educational viewing! Mark Russinovich - Advanced Malware Cleaning http://www.microsoft.com/emea/spotli...px?videoid=359 Good luck ![]() | ||||||||||||
| | #7 (permalink) |
| Guest | Re: Rootkit help PLEASE!!! From: "gardnertj00" <guest@xxxxxx-email.com> | Ok so it started with a pop up saying that I will no longer received updates from | windows security and that my version of vista is not genuine. Dell has check the system | and it is genuine. I downloaded avast and this is the what it said: suspicious malware: | c:/windows/system32/kdila.exe.rootkit:hiddenfile. ccrtklum.dll Can anyone please tell | me how to get rid of this? I am unable to uninstall spysweeper or download the updated | version of mcafee because of this. Any help would be greatly appreciated. -- | gardnertj00 You are asking in the WRONG place. There are anti virus news groups which are best suited for such subject matter. In the Microsoft.* hierarchy it is... microsoft.public.security.virus Or you can find others in the alt.* hierarchy. You have two choices. I think the second is best for you. The first... GMER -- http://www.gmer.net/index.php Undoubtedly the *best* anti rootkit utility out there. The second... Register for an account and then create a post on the SpyKiller with the above information. http://www.thespykiller.co.uk/index.php?board=3.0 Tell them I sent you there. -- Dave http://www.claymania.com/removal-trojan-adware.html Multi-AV - http://www.pctipp.ch/downloads/dl/35905.asp |
| Display Modes | |
| please help - rootkit problem | Helltech | System Security | 4 | 09-01-2008 01:39 AM |
| Rootkit | silver hair | Vista General | 3 | 07-12-2008 03:48 PM |
| Rootkit | ssplal | Vista security | 2 | 03-10-2008 09:57 AM |
| SecuROM = rootkit? | Tessiero | Vista Games | 12 | 11-29-2007 04:20 PM |
| How do I get rid of a rootkit | T5 | Vista security | 8 | 05-13-2007 06:17 PM |
| Complimentary Industry Resources Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today! |
