| Vista Home Premium 32bit | Problem Disabling Vista Search Index I'm trying to disable vista search indexing but when I uncheck "Index this drive for faster searching" in Local Disk properties I keep gettined "Access Denied." It says that I need to provide administrator permission to change these attributes. So.. then I went into the security tab and messed with a few things... Under 'Group or user names' there should be Authenticated Users, SYSTEM, Administators, Users but some how Authenticated Users got deleted under that list. I'm kind of lost here and don't know what I'm doing exactly. Can I please get some help? I'm using Vista Home Premium 32 bit and was follow the directions in http://forum.notebookreview.com/showthread.php?t=166532 Thanks! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Problem Disabling Vista Search Index I'm trying to disable vista search indexing but when I uncheck "Index this drive for faster searching" in Local Disk properties I keep gettined "Access Denied." It says that I need to provide administrator permission to change these attributes. So.. then I went into the security tab and messed with a few things... Under 'Group or user names' there should be Authenticated Users, SYSTEM, Administators, Users but some how Authenticated Users got deleted under that list. I'm kind of lost here and don't know what I'm doing exactly. Can I please get some help? I'm using Vista Home Premium 32 bit and was follow the directions in http://forum.notebookreview.com/showthread.php?t=166532 Thanks! This tutorial will show you how to easily disable the Search Index. Index - Enable or Disable Hope this helps, Shawn |
| Vista Home Premium 32bit | Re: Problem Disabling Vista Search Index Wow this helps me a lot, thanks! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Problem Disabling Vista Search Index Your welcome Ksp. Shawn |
| Windows Vista ultimate x64 Search engine issues - Search fails to index | Vista General | |||
| vista search - index doesn't update | General Discussion | |||
| Search index problem | Vista file management | |||
| Disabling Vista Auto-Search for drivers. | Vista hardware & devices | |||
| opening a file within Windows Search Index problem | Vista file management | |||
