| | External Drive Problem I just bought a new Samsung HD753LJ and placed it in an Antec MX-1 case. At this stage I do not have my notebook eSATA ExpressCard so I hooked it up using the USB connection. The device drivers installed fine and it shows up as working in Device Manager, but it does not show at Start > Computer. I have rebooted and I get the same issue. If anyone can tell me how I can access this drive, I would be truely grateful. |
| | RE: External Drive Problem Try going to Control Panel>System and Maintenance>Administrative Tools>Computer Management>Disk Management Then format the drive. HTH "pbl" wrote: Quote: > I just bought a new Samsung HD753LJ and placed it in an Antec MX-1 case. At > this stage I do not have my notebook eSATA ExpressCard so I hooked it up > using the USB connection. The device drivers installed fine and it shows up > as working in Device Manager, but it does not show at Start > Computer. I > have rebooted and I get the same issue. If anyone can tell me how I can > access this drive, I would be truely grateful. > |
| 1 TB External Hard Drive Problem | Vista hardware & devices | |||
| Problem with External Drive | General Discussion | |||
| USB external hard drive problem. | Vista hardware & devices | |||
| USB External Drive Problem | Vista General | |||
| External hard drive problem | Vista hardware & devices | |||
