Vista - Power Management/Power Options in Vista
Old 08-28-2008   #1 (permalink)
MarkR
System: 3.4 GHZ Pentium Desktop
Motherboard: DFI Lanparty 875P-T
BIOS: Award v6.00PG (3/25/05)
Display Adapter: NVidia GeForce 7600 GS
Monitor: Dell 2407 WFP-HC
Router: Linksys BEFW11S4 v4
OS: Windows Vista Premium SP1
wireless mouse, wired usb keyboard
I can set the Advanced Power Options so that the ON/OFF button or selection
of "hibernate" in the start menu will put the computer into hibernation and
it works OK. When I configure the advanced settings to make the computer go
into either the hibernate, hybrid sleep or sleep mode automatically after the
number of minutes designated in the "settings", the computer remains in the
full powered up mode after the number of minutes designated.
My BIOS allows for two ACPI global states: S1 or S3. I have tried both
settings and neither seems to correct the problem.
Any suggestions on how I can get my computer to go into a reduced power
state automatically after a designated number of minutes?
Thank you
Old 08-28-2008   #2 (permalink)
MarkR
RE: Power Management/Power Options in Vista
Further to my previous post, I did not have this problem prior to upgrading
from Windows XP Professional to Windows Vista Premium.
> Thank you
Old 08-28-2008   #3 (permalink)
Michael Walraven
Re: Power Management/Power Options in Vista
If the computer is actively sharing files or media then it will not go to
sleep (the sharing would be interrupted if it did).
Check your multimedia settings in advanced settings.
Also in network and sharing: towards bottom see media sharing.
Michael
"MarkR" <MarkR@xxxxxx> wrote in message
news:65F8B9CF-009A-4B1A-AE5F-1F7BD3659AB3@xxxxxx
> upgrading
>> selection
>> and
>> go
>> the
>> the
>> Thank you
Old 08-28-2008   #4 (permalink)
Phillips
Event Viewer would tell why the computer could not enter sleep power saving
mode. Leave BIOS settings on S3 to save more power.
Also, check these tips:
Power Options and Sleep Mode Problems
Michael
news:BB36B860-145B-4855-87F5-24498F3649E2@xxxxxx
> selection
> and
> go
> the
> the
> Thank you
Old 08-29-2008   #5 (permalink)
MarkR
Excellent advice in both replies -- Thank you. I can now get my computer to
automatically go into hibernation after 15 minues as configured in the
advanced settings.
Also, Phillips is correct -- the following link is one of the best tutorials
on this subject matter to be found on the web:
> Michael
> > selection
> > and
> > go
> > the
> > the
> > Thank you
Solved Power Options Corrupt (power plan unavailable) General Discussion
Useful tool for power enthusiasts on the go (advanced power options) General Discussion
Power Management Schedule Task Options VB Script
Power management in Vista Vista General
Vista HDD Power Management Vista General
