Vista Tutorial - How to read Vista registry values containing @DllFilename.dll?
Old 09-17-2006   #1 (permalink)
Mark Findlay
Guest
Our Win32 app currently reads various values from registry strings. But in
Vista, these values no longer contain the string we're expecting. Instead,
they contain something like:
@themeuidll.dll.-852
I assume that this means we need to access the themui.dll file and reference
something by 852? Is it that we need to load the dll then extract the string
resource identified by the ordinal 852 to get the actual string value we're
looking for?
I'm pretty new to Vista so any direction on this would be most welcome
Thanks!
Mark
Old 09-18-2006   #2 (permalink)
Rick Rogers
Guest
Re: How to read Vista registry values containing @DllFilename.dll?
Might want to check the Vista SDK, or check with a group that supports the
language you're app is written in.
SDK:
http://www.microsoft.com/downloads/d...displaylang=en
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Mark Findlay" <mfindlay@speakeasy.org> wrote in message
news:uOT%23I5s2GHA.4228@TK2MSFTNGP06.phx.gbl...
> reference something by 852? Is it that we need to load the dll then
> extract the string resource identified by the ordinal 852 to get the
> actual string value we're looking for?
> Thanks!
> Mark
Set/Create Registry Values PowerShell
Writing values to Registry General Discussion
Remote HKU registry values PowerShell
Reporting on registry values PowerShell
need some registry values Vista General
