Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
br> br> |
| | Thread Tools | Display Modes |
| Guest | Mouse interferes with sound Does anyone know why moving the mouse generates sound from my speaker? It's a slight ringing noise, it has happened to me on every version of Windows since 2000, probably before that as well, and it's horribly annoying. It's even worse when I use the mouse to drag a scrollbar or a window. Since I've never had a windows installation where this DIDN'T happen, I'm assuming it's a global problem and others have experienced this as well. If you don't know what I'm talking about turn the volume on your speakers way up and then move the mouse around. If anyone knows how to get rid of this I would really appreciate it. |
| | #2 (permalink) | ||||||||||||
| Guest | Re: Mouse interferes with sound It's called radio interference and you get rid of it by placing your speakers *well* away from the PC. I've got a fairly loud static, anyway, because the base woofer cabinet is practically leaning against my tower. If I turn my speakers way up, the small battery powered clock that's 6' away from the desk can be heard tick-tocking. Probably doesn't help that I have an Army surplus steel desk. Mine's a wired mouse, currently. Perhaps a wireless mouse would help the problem. Or perhaps it would be worse. -- Gary S. Terhune MS-MVP Shell/User http://grystmill.com "Zachary Turner" <divisortheory@xxxxxx> wrote in message news:79d7098c-238d-40a9-b780-1b17ab9a41e2@xxxxxx
My System Specs![]() | |||||||||||||
| | #3 (permalink) | ||||||||||||
| Guest | Re: Mouse interferes with sound "Zachary Turner" <divisortheory@xxxxxx> wrote in message news:79d7098c-238d-40a9-b780-1b17ab9a41e2@xxxxxx
motherboards. If you have on-board audio, the best solution is to get a PCI sound card. This is usually not a problem on recent motherboards with on-board multi-channel HD audio. | ||||||||||||
| | #4 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Mouse interferes with sound I'll ask you, too. What makes onboard sound different than a PCI card in this respect? -- Gary S. Terhune MS-MVP Shell/User http://grystmill.com "Ian D" <taurus@xxxxxx> wrote in message news:eSMcy%23uDJHA.3456@xxxxxx
My System Specs![]() | |||||||||||||||||||||||||
| | #5 (permalink) | ||||||||||||
| Guest | Re: Mouse interferes with sound "Gary S. Terhune" <none> wrote in message news:u8wAgxwDJHA.4724@xxxxxx
amplification settings, and most noticeable when no other sound is being generated. On board sound codecs rely on the CPU for processing and are tightly integrated into the motherboard circuitry, and subjected to electrical noise, especially on the v+ line. A lot of the noise is generated by changes in processing load caused by interrupts. Most interrupt noise is high frequency and random, and blends into the normal backgroung hiss. A moving mouse generates a stream of repetitive interrupts in the audible range, the effects of which can be clearly heard when the volume is set high. It's the mouse generated noise that is the cause of complaints. The PCI bus is more electrically isolated from CPU activity. Also, most quality PCI sound cards do their own on card hardware sound processing, and have additional filtering on the power connections. | ||||||||||||
| | #6 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Mouse interferes with sound Thank you, <s>. -- Gary S. Terhune MS-MVP Shell/User http://grystmill.com "Ian D" <taurus@xxxxxx> wrote in message news:uMqSXo2DJHA.528@xxxxxx
| Display Modes | |
| The mouse cursor and the mouse hot spot are not the same location. | Martin | Vista hardware & devices | 0 | 03-31-2008 10:34 AM |
| Jerky Mouse & Sound Issues | Ben Trasherson | Vista performance & maintenance | 10 | 07-09-2007 10:04 PM |
| Text Disappears On Mouse Enter or Mouse Leave | J. W. T. Kottekoe | Vista General | 0 | 01-21-2007 03:11 PM |
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Kevin John Panzke | Vista General | 1 | 10-14-2006 06:36 AM |
| Mouse Drivers MS Optical Wheel Mouse -- Vista Beta 2 64-bit | OS-Wiz | Vista hardware & devices | 3 | 06-28-2006 10:10 AM |
| Complimentary Industry Resources Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today! |
