Vista Tutorial - Vista Home Premium OEM 32bit to Ultimate OEM 64bit
Old 09-05-2008   #1 (permalink)
Doug
Guest
I have a PC running an OEM 32bit version of Windows Vista Home Premium.
I am contemplating installing an extra 2GB of RAM and am wondering if this
change of spec entitles me to download and purchase the OEM 64bit version of
Vista Ultimate.
Microsoft seem to be reticent about their financial options. As a home user
I do not wish to fork out for the full/retail version.
Doug
Old 09-05-2008   #2 (permalink)
DDW
Guest
Re: Vista Home Premium OEM 32bit to Ultimate OEM 64bit
>Vista Ultimate.
No change of spec is necessary. If you found a retailer that has what
you want at the price you want to pay... go for it.
Note that you will have to do a clean install. You can't upgrade.
Realize that there can be no expectation of support from Microsoft for
an OEM version.
DDW
Reply via this group
No email please
Old 09-05-2008   #3 (permalink)
Carey Frisch [MVP]
Guest
Using more than 2GB of RAM is really not necessary.
Read the following:
The Vista RAM puzzle: Is 2GB enough?
http://blogs.zdnet.com/Bott/?p=282
Only "retail" editions of Windows Vista allow you to
obtain 64-bit Windows Vista discs from Microsoft.
OEM versions would require a new 64-bit license and
would have to be purchased from a third-party source such as newegg.com.
Example: http://www.newegg.com/Product/Produc...82E16832116488
Carey Frisch
Microsoft MVP
Windows Desktop Experience -
Windows Vista Enthusiast
"Doug" <doug@xxxxxx> wrote in message news:uGhL6Q4DJHA.4976@xxxxxx
Vista Ultimate.
Doug
Old 09-05-2008   #4 (permalink)
DDW
Guest
"Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote:
>Read the following:
While you can read, your comprehension leaves something to be desired.
The OP was looking to use the purchase of 2G of RAM as the "hardware"
qualifier so that an OEM version of Vista could be purchased.
The OP knew that. Like I said...
DDW
No email please
Old 09-05-2008   #5 (permalink)
AJR
Guest
Doug regarding "...am wondering if this
version...." - Simple answer "no". technically there ae no OEM versions to
purchase via download - "OEM version"is applied to software installed by the
manufacturer.
Your computer must be 64 bit capable - processor, chipset and so forth
otherwise the OS will not install - also it must be a clean install not an
upgrade.
Regarding 32 bit RAM - lots of opinions about 2 gig versus 4 gig. Video and
audio drivers are loaded in the bottom half of the memory stack -(one of the
application limitations in addtition to addressing that limits 32 bit to 4
gig). If you are a heavy graphics and audio "usere" 4 gigs is a definite
assest.
In addition , most users have Vista set to manage virtual memory - Vista
sets virtual memory size based on RAM - 2 gig RAM and virtual memory about
3.5 gigs - 4 gigs RAM memory 6 gigs. Virtual memory, Superfetch and
ReadyBoost work in concert- draw your own conclusions.
> of
> Vista Ultimate.
> user
> Doug
Old 09-05-2008   #6 (permalink)
Synapse Syndrome
Guest
"Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message
news:OxYyEx4DJHA.4800@xxxxxx
> Read the following:
That really depends on what you are using the machine for.
Common everyday work scenario for me:
Open apps for working between them-
ArchiCAD 11
Adobe Photoshop CS3
Adobe Acrobat Pro 8
3ds Studio Max 10
Sketchup Pro 6
sometimes Adobe Illustrator CS3
Skype
Outlook 2007
2x 22" CRT monitors @ QXGA resolution
ss.
Old 09-06-2008   #7 (permalink)
Brian W
Guest
> of
> Vista Ultimate.
> user
> Doug
You don not need to purchase hardware, Vista Ultimate x64 OEM is available
from Amazon:
http://www.amazon.com/Windows-Ultima...692338&sr=8-20
Or, if you are in the UK:
http://www.amazon.co.uk/Windows-Vist...692449&sr=8-14
Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media Vista installation & setup
Have 32bit OEM Vista Home Premium - Need 64bit Drivers
vista premium 32bit to ultimate 64bit upgrade gone wrong! Vista installation & setup
go back from 64bit to 32bit home premium vista Vista installation & setup
Vista Home Premium 32bit Upgrade to Vista Ultimate 64bit Vista installation & setup
