| | RC1 Loads Significantly Slower than Beta 2 Cross posting to make sure question is being asked in correct news group. pennhaven wrote (9/17/2006 4:05 PM in microsoft.public.windows.vista.performance_maintenance Re: RC1 Startup Significantly Slower): > I was quite surprised to find that system startup is *significantly* > slower with RC1 relative to Beta 2. I am talking about 45 seconds longer > to load the desktop from POST. I expected to see a speed improvement with > RC1, not a deterioration. > > After reviewing the System Event Log it seems the primary culprit is the > "Application Experience Lookup Service" which apparently is taking 45 to > 47 seconds to load in RC1 versus only 7 seconds in Beta 2. > > Can this service be disabled? Is this a known issue that will be fixed? > Other thoughts, suggestions, experience? |
| | RE: RC1 Loads Significantly Slower than Beta 2 try msconfig...system...uncheck application experience..i am sure there are others to disable also..which I could find a good list... "pennhaven" wrote: > Cross posting to make sure question is being asked in correct news group. > > pennhaven wrote (9/17/2006 4:05 PM in > microsoft.public.windows.vista.performance_maintenance Re: RC1 Startup > Significantly Slower): > > > I was quite surprised to find that system startup is *significantly* > > slower with RC1 relative to Beta 2. I am talking about 45 seconds longer > > to load the desktop from POST. I expected to see a speed improvement with > > RC1, not a deterioration. > > > > After reviewing the System Event Log it seems the primary culprit is the > > "Application Experience Lookup Service" which apparently is taking 45 to > > 47 seconds to load in RC1 versus only 7 seconds in Beta 2. > > > > Can this service be disabled? Is this a known issue that will be fixed? > > Other thoughts, suggestions, experience? > |
| | Re: RC1 Loads Significantly Slower than Beta 2 Tried disabling Application Experience in msconfig. It loaded anyway - took 48 seconds. Opened msconfig and Application Experience was still unchecked. Must be an override in the the registry that forces it to load anyway. Alec wrote: > try msconfig...system...uncheck application experience..i am sure there are > others to disable also..which I could find a good list... > > "pennhaven" wrote: > >> Cross posting to make sure question is being asked in correct news group. >> >> pennhaven wrote (9/17/2006 4:05 PM in >> microsoft.public.windows.vista.performance_maintenance Re: RC1 Startup >> Significantly Slower): >> >>> I was quite surprised to find that system startup is *significantly* >>> slower with RC1 relative to Beta 2. I am talking about 45 seconds longer >>> to load the desktop from POST. I expected to see a speed improvement with >>> RC1, not a deterioration. >>> >>> After reviewing the System Event Log it seems the primary culprit is the >>> "Application Experience Lookup Service" which apparently is taking 45 to >>> 47 seconds to load in RC1 versus only 7 seconds in Beta 2. >>> >>> Can this service be disabled? Is this a known issue that will be fixed? >>> Other thoughts, suggestions, experience? |
| Beta made it SLOWER and Can't post PHOTOS | Live Mail | |||
| Vista Copy Speed over the network is slower that XP SP2 and OSX..much slower? | Vista General | |||
| Vista Copy Speed over the network is slower that XP SP2 and OSX..much slower? | Vista networking & sharing | |||
| Memory sticks are significantly slower in vista then xp? | Vista General | |||
| RC1 Startup Significantly Slower | Vista performance & maintenance | |||
