| | Batch-file not working: PATH-problem? Hello, I wrote a Batch-file in order to use bluetooth with one click in stead of 2, but recently it didn't work anymore. Here is the Batch-file: @echo off start D:\bluetooth\BTTray.lnk start D:\bluetooth\TosBtMng.lnk I used .lnk-files, because I coulnd't find out how to insert spaces in a Batch-file (like Program Files: it reads Program and the Files it ignores, so it can't find the path. Later I found out that it could be solved by putting the complete path between""). The problem is: when I run the Batch-file it opens cmd, but then just shows the path of where the Batch-file is located: when copy the file to the C; I just get path C: in cmd. When I use it in path D:\bluetooth it just shows that path as starting point in Cmd. Before it would run the files and Bluetooth would function afterwards: now: nothing. I did install Java SDK and had to ad the Bin-folder of Java to the PATH in the System Variables under Environment Variables. At first I just cleared the PATH and had only the path of the Java-bin-folder. Later I found out I had done something wrong, so I added severall paths as shown below. My PATH is now: C:\windows\system32;C:\windows;C:\Windows\System32\Wbem;C:\program files\java\jdk1.6.0_10\bin In the user Variables there is no PATH. Does anyone know the answer? I know it's not a major problem, but it bugs me and keeps me "out of control". |
| | Re: Batch-file not working: PATH-problem? @echo off start "D:\bluetooth\BTTray.lnk" "D:\bluetooth\BTTray.lnk" start "D:\bluetooth\TosBtMng.lnk" "D:\bluetooth\TosBtMng.lnk" -- Please use the Communities guidelines when posting. http://www.microsoft.com/wn3/locales...help_en-us.htm Use the "Ratings" feature. It helps the new users. Mark L. Ferguson MS-MVP https://mvp.support.microsoft.com/profile/Mark.Ferguson "DaniëlRie" <DaniëlRie@xxxxxx> wrote in message news:8BB08669-4F93-496B-A587-8945A5E8C238@xxxxxx Quote: > Hello, > > I wrote a Batch-file in order to use bluetooth with one click in stead of > 2, > but recently it didn't work anymore. > > Here is the Batch-file: > @echo off > start D:\bluetooth\BTTray.lnk > start D:\bluetooth\TosBtMng.lnk > > I used .lnk-files, because I coulnd't find out how to insert spaces in a > Batch-file (like Program Files: it reads Program and the Files it ignores, > so > it can't find the path. Later I found out that it could be solved by > putting > the complete path between""). > > The problem is: > when I run the Batch-file it opens cmd, but then just shows the path of > where the Batch-file is located: when copy the file to the C; I just get > path > C: in cmd. When I use it in path D:\bluetooth it just shows that path as > starting point in Cmd. > > Before it would run the files and Bluetooth would function afterwards: > now: > nothing. > > I did install Java SDK and had to ad the Bin-folder of Java to the PATH in > the System Variables under Environment Variables. At first I just cleared > the > PATH and had only the path of the Java-bin-folder. Later I found out I had > done something wrong, so I added severall paths as shown below. > > My PATH is now: > C:\windows\system32;C:\windows;C:\Windows\System32\Wbem;C:\program > files\java\jdk1.6.0_10\bin > In the user Variables there is no PATH. > > Does anyone know the answer? I know it's not a major problem, but it bugs > me > and keeps me "out of control". |
| | Re: Batch-file not working: PATH-problem? I'm affraid the problem still remains: when I open the batch-file it just opens Cmd and dispays thepath from where I opened it. Nothing more. "Mark L. Ferguson" wrote: Quote: > @echo off > start "D:\bluetooth\BTTray.lnk" "D:\bluetooth\BTTray.lnk" > start "D:\bluetooth\TosBtMng.lnk" "D:\bluetooth\TosBtMng.lnk" > > -- > Please use the Communities guidelines when posting. > http://www.microsoft.com/wn3/locales...help_en-us.htm > Use the "Ratings" feature. It helps the new users. > Mark L. Ferguson MS-MVP > https://mvp.support.microsoft.com/profile/Mark.Ferguson |
| | Re: Batch-file not working: PATH-problem? "DanielRie" <DanielRie@xxxxxx> wrote in message news:BBDC76A5-C582-4EE7-AE20-E7B86F8839C5@xxxxxx Quote: > I'm affraid the problem still remains: when I open the batch-file it just > opens Cmd and dispays thepath from where I opened it. Nothing more. What do you mean it displays the path where you opened it? In the prompt> ? Run the script without echo off and paste what it says here. Paste the script too. See if anybody can tell you the default PATH for Vista is. I do not have a Vista machine to hand. ss. |
| Batch file problem | VB Script | |||
| vista batch file problem | Vista General | |||
| batch file calling exe file problem | Vista security | |||
| Vista: Batch file cannot find path of exe | Vista General | |||
