| | S3 Sleep problem i am trying to use S3 sleep. computer goes to sleep normally but when i attempt to wake computer, power lights, HD activity light flashes, power fans turn off, screen remainsa blank then after a couple of seconds all power is gone, then after a couple of seconds power returns and goes in this continued loop. and only rectified by removing power cord. No problem if bios set to S1 sleep mode it is gigabyte MB GA-X48- DQ6 bios F7 latest ( F6 was same) 9600 GT PCI Express grapics card Vista 64 Ultimate sp1 all latest driverss have even reformatted hard drive so complete clean install . any help will be appreciated thanks Chris |
| | Re: S3 Sleep problem Hi Mark thanks for that. my driver is acpi driver ver 6.0.6001.18000 dated 21-6-2006 and doing the check on line update vista reports i have most upto date driver. yes vista works ok boots up ... just appears this S3 problem Chris "Mark L. Ferguson" wrote: Quote: > "sleep normally' makes me assume you successfully boot to Windows. Look at > Device Manager in Control Panel. The Properties of the 'computer' item in > the device list will show you the ACPI interface driver condition. You might > let it 'update driver' online. > > -- > Please use the Communities guidelines when posting. > http://www.microsoft.com/wn3/locales...help_en-us.htm > Use the "Ratings" feature. It helps the new users. > Mark L. Ferguson MS-MVP > https://mvp.support.microsoft.com/profile/Mark.Ferguson > > "ukguy" <ukguy@xxxxxx> wrote in message > news:9F89D974-A024-429C-911F-8DB0C8F1ED6C@xxxxxx Quote: > > i am trying to use S3 sleep. computer goes to sleep normally but when > > i > > attempt to wake computer, power lights, HD activity light flashes, power > > fans turn off, screen remainsa blank then after a couple of seconds > > all > > power is gone, then after a couple of seconds power returns and goes in > > this continued loop. and only rectified by removing power cord. No > > problem if bios set to S1 sleep mode > > > > it is gigabyte MB GA-X48- DQ6 bios F7 latest ( F6 was same) > > 9600 GT PCI Express grapics card > > Vista 64 Ultimate sp1 > > all latest driverss > > have even reformatted hard drive so complete clean install . > > > > any help will be appreciated > > thanks > > Chris > > |
| | Re: S3 Sleep problem I agree with Rick. The device and its driver are controlling how well Windows can do the sleep awakening. The Windows "HAL' interface offers the driver the 'chance' to do it right, but it's up to the device maker to do that well enough for your purpose. Settling for hibernation is your cheapest solution. -- Please use the Communities guidelines when posting. http://www.microsoft.com/wn3/locales...help_en-us.htm Use the "Ratings" feature. It helps the new users. Mark L. Ferguson MS-MVP https://mvp.support.microsoft.com/profile/Mark.Ferguson "ukguy" <ukguy@xxxxxx> wrote in message news:240B7342-C2AE-422B-8512-A84846589786@xxxxxx Quote: > Hi Mark > > thanks for that. > > my driver is acpi driver ver 6.0.6001.18000 dated 21-6-2006 > and doing the check on line update vista reports i have most upto > date > driver. > yes vista works ok boots up ... just appears this S3 problem > > Chris > > > > "Mark L. Ferguson" wrote: > Quote: >> "sleep normally' makes me assume you successfully boot to Windows. Look >> at >> Device Manager in Control Panel. The Properties of the 'computer' item in >> the device list will show you the ACPI interface driver condition. You >> might >> let it 'update driver' online. >> >> -- >> Please use the Communities guidelines when posting. >> http://www.microsoft.com/wn3/locales...help_en-us.htm >> Use the "Ratings" feature. It helps the new users. >> Mark L. Ferguson MS-MVP >> https://mvp.support.microsoft.com/profile/Mark.Ferguson >> >> "ukguy" <ukguy@xxxxxx> wrote in message >> news:9F89D974-A024-429C-911F-8DB0C8F1ED6C@xxxxxx Quote: >> > i am trying to use S3 sleep. computer goes to sleep normally but >> > when >> > i >> > attempt to wake computer, power lights, HD activity light flashes, >> > power >> > fans turn off, screen remainsa blank then after a couple of seconds >> > all >> > power is gone, then after a couple of seconds power returns and goes >> > in >> > this continued loop. and only rectified by removing power cord. No >> > problem if bios set to S1 sleep mode >> > >> > it is gigabyte MB GA-X48- DQ6 bios F7 latest ( F6 was same) >> > 9600 GT PCI Express grapics card >> > Vista 64 Ultimate sp1 >> > all latest driverss >> > have even reformatted hard drive so complete clean install . >> > >> > any help will be appreciated >> > thanks >> > Chris >> > |
| | Re: S3 Sleep problem you can visit Intel site for an update of you chipset, since you have X48 chipset installed on your mobo. anyways, here is the link http://www.intel.com/support/chipsets/sb/CS-028823.htm "ukguy" <ukguy@xxxxxx> wrote in message news:9F89D974-A024-429C-911F-8DB0C8F1ED6C@xxxxxx Quote: >i am trying to use S3 sleep. computer goes to sleep normally but when >i > attempt to wake computer, power lights, HD activity light flashes, power > fans turn off, screen remainsa blank then after a couple of seconds > all > power is gone, then after a couple of seconds power returns and goes in > this continued loop. and only rectified by removing power cord. No > problem if bios set to S1 sleep mode > > it is gigabyte MB GA-X48- DQ6 bios F7 latest ( F6 was same) > 9600 GT PCI Express grapics card > Vista 64 Ultimate sp1 > all latest driverss > have even reformatted hard drive so complete clean install . > > any help will be appreciated > thanks > Chris > |
| Sleep problem | Vista General | |||
| Sleep Problem | General Discussion | |||
| Another but different sleep problem | Vista General | |||
| SLEEP PROBLEM | Vista General | |||
| Vista Sleep Problem / Network Problem | Vista networking & sharing | |||
