Vista - Problem Reporting Tool
Old 09-19-2006   #1 (permalink)
=?Utf-8?B?VmlzdCBpcyBDb29s?=
How do you send a report anout vista to MS using the file transfer manager
that they want you to use. I have downloaded it and installed it but cannot
figure out how to send any reports.
Old 09-19-2006   #2 (permalink)
=?Utf-8?B?YWJja2lk?=
RE: Problem Reporting Tool
I think you are talking of this -
Goto Start - All Programs - Maintenance - Problem Reports and Solutions.
abc.
Old 09-19-2006   #3 (permalink)
=?Utf-8?B?VG9tIFppZWdtYW5u?=
On your desktop click on the 'How To Share Feedback' icon, then download the
problem reporting tool and it will install the tool and the File Transfer
Manager and you can then file bug reports.
Tom Ziegmann
Microsoft Certified Professional
Windows Vista / Server Longhorn TechBeta Tester
Windows Server 2003 SP2 TechBeta Tester
Old 09-19-2006   #4 (permalink)
Colin Barnhorst
Re: Problem Reporting Tool
What are you preparing the bug report with? If you are using the MBC you
simply finish the report and make sure the box is checked for "Submit this
report to Microsoft now" on the last page.
"Vist is Cool" <Vist is Cool@discussions.microsoft.com> wrote in message
news:95C97852-B9A9-45C4-810E-6E14291AFF8A@microsoft.com...
> cannot
Problem Reporting Tool/Beta Client Vista General
Problem reporting tool Vista General
Microsoft Beta Client - problem reporting tool. Vista General
Problem reporting tool is broken Vista installation & setup
Problem reporting tool - doesn't install Vista General
