Right click options i IE7 are gone - bug ?
  1. #1
    Allan Knaap Guest
    For some reason i am not longer able to right click in IE7 and choose ex.
    copy. Am i the only one or could it be a bug ?
    Best Regards
    Allan Knaap
  2. #2
    =?Utf-8?B?Qm9uZXM=?= Guest
    RE: Right click options i IE7 are gone - bug ?
    Sounds like this problem is specific to your pc as I can right click in IE7.
    Try running IE with no add-ons and see if it still happens.
    > Best Regards
    > Allan Knaap
Right click options i IE7 are gone - bug ? problems?
Settings.ini is being used by another process. Close the other programs and then click, Retry, or Click to Cancel sidebar. phanileo Vista General 0 27 Nov 2009
Partition Management--How do you label Partitions via Disk Mgmt's Rt. Click to maximize options? Chad Harris Vista installation & setup 0 22 Apr 2009
Missing "right click" menu options swarkentien General Discussion 3 02 Jun 2008
remove some right click options dwolf Vista General 4 27 Feb 2008
No right-click options in IE7 Tim Vista General 2 28 Sep 2006
