Vista - "Add or remove programs" not visible in Control Panel
Old 09-14-2008   #1 (permalink)
Stan in South Africa
Not visible in either views of my Control Panel.
Any suggestions will be appreciated
Old 09-14-2008   #2 (permalink)
Ramesh Srinivasan, MS-MVP
Re: "Add or remove programs" not visible in Control Panel
It's now called "Programs and Features".
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
The Winhelponline Blog http://www.winhelponline.com/blog
"Stan in South Africa" <me@xxxxxx> wrote in message
news:elqXPLuFJHA.2456@xxxxxx
Old 09-15-2008   #3 (permalink)
trigonometry1972 |
I'll suggest a couple of ways to skin the cat. First do a search
in the control panel and then click on the results. Or go to
control panel > programs > programs and features
Old 09-15-2008   #4 (permalink)
Re: "Add or remove programs" not visible in Control Panel Thank You!
THANK YOU!
Unable To Remove Uninstalled Programs From "Programs And Features". Software
Add/Remove Programs in Control Panel broken Vista installation & setup
Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" Vista General
Control Panel / "Programs and Features" Won't Open Vista performance & maintenance
Add Remove programs has disappeared from Control Panel Vista General
