Vista - Hibernate Problem
Old 09-15-2008   #1 (permalink)
Shahnaz Shahbaz
Hibernate Problem
I have a SONY VAIO laptop with Windows Vista Business.
I do not have any HIBERNATE option in Start Menu.
How can I resolve the problem.Please help.
Shahnaz
Old 09-15-2008   #2 (permalink)
Gordon
Re: Hibernate Problem
"Shahnaz Shahbaz" <shahbaz@xxxxxx> wrote in message
news:eBVgLRyFJHA.3392@xxxxxx
> Shahnaz
Click on the Start Button - the hibernate button is just to the right of the
Search field....un-named!
Old 09-15-2008   #3 (permalink)
Theory of Everything
The hibernation function is not always there, due to bad vista design (as
with everything else). read my post to the OP for info about this
"Gordon" <gordonbparker@xxxxxx> wrote in message
news:Ohdn4UyFJHA.1460@xxxxxx
>> Shahnaz
> the Search field....un-named!
Old 09-15-2008   #4 (permalink)
If you have used the Disk Cleanup Utility and utilized it to clear the
hibernation file, you may be surprised to find that the Hibernate option is
no longer available. You can restore the hibernate option by following these
instructions:
1. Click the Start button.
2. Select All Programs.
3. Select Accessories.
4. Right-click on Command Prompt.
5. Select Run as Administrator.
6. When the UAC prompt appears, click Continue.
7. Type powercfg /hibernate on and press Enter on your keyboard.
8. Close the Command Prompt window.
9. Reboot your PC.
Tell me if this helps!
> Shahnaz
Old 09-16-2008   #5 (permalink)
Shahnaz Shahbaz
Dear Micheal
I do not have any HIBERNATE option in menus.
Shahnaz
"Michael Walraven" <mexxwalraven@xxxxxx> wrote in message
news:B8A2B47F-2915-4CE6-80A6-3E91F8160CEB@xxxxxx
Quote:
> Start button options are controlled in the Power Options dialogue
> Start Orb
> 'Power Options'
> change plan settings for the power options you use
> change advanced power settings
> Power Buttons and lid
> Start Menu power button
> normal settings are:
> On Battery: Hibernate
> Plugged in: Sleep
> change as you will.
> Michael
>> Shahnaz
hibernate problem Vista General
Hibernate problem Vista General
Vista Hibernate Problem General Discussion
Problem with Hibernate Vista General
