Vista - Rename Problems
Old 09-16-2008   #1 (permalink)
Vista ultimate x64
Rename Problems
I have a problem trying to rename files on my desktop screen, when I click on the file and then click rename the box only stays open for a few seconds making renaming impossible. Any suggestions or ways of resolving this issue would be much appreciated.
Old 09-16-2008   #2 (permalink)
oscar
RE: Rename Problems
Try moving those desktop files to the Document folder and rename them there.
oscar
....Right click is your very good friend...
> Cski
Old 09-22-2008   #3 (permalink)
Vista ultimate x64
Re: Rename Problems
I tried all of the usual stuff right click, reset to earlier known working condition but to no avail. Ended up re-installing everything again what a ball ache. would love to know what caused it all for future reference.
Rename errorin Vista - multiple file rename Vista file management
Rename PC Vista General
Rename a tag Vista file management
rename bug from CMD Vista file management
Can't rename a file due to permission problems Vista security
