Vista - Guide about setting up and mounting a virtual machine
Old 09-20-2008   #1 (permalink)
Tony
I need a link to a recent, thorough, yet compact guide about setting up and
mounting a virtual machine XP and Vista- on a Vista Ultimate PC with 4 G
memory and VPC 2007..
Kind regards,
Tony Thijs
Oriolus Publishing
Old 09-20-2008   #2 (permalink)
John Barnett MVP
Re: Guide about setting up and mounting a virtual machine
Tony, I can't help you with a guide to VPC 2007 because, currently, I
haven't got around to preparing one. My website does, however, contain a
guide to VMware Workstation.
While VPC 2007 is free it isn't as flexible as VMware workstation; you also
don't get USB support on VPC 2007.
John Barnett MVP
Associate Expert
Windows Desktop Experience
Web: http://xphelpandsupport.mvps.org
Web: http://vistasupport.mvps.org
Web: http://www.silversurfer-guide.com
The information in this mail/post is supplied "as is". No warranty of any
kind, either expressed or implied, is made in relation to the accuracy,
reliability or content of this mail/post. The Author shall not be liable for
any direct, indirect, incidental or consequential damages arising out of the
use of, or inability to use, information or opinions expressed in this
mail/post..
"Tony" <tonythecatnospampleasemiauw@xxxxxx> wrote in message
news:CF7C3CD9-DBF7-455C-A490-C8EE5BECB925@xxxxxx
Quote:
> Hi,
> and mounting a virtual machine XP and Vista- on a Vista Ultimate PC with 4
> G memory and VPC 2007..
> Kind regards,
> Tony Thijs
> Oriolus Publishing
Old 09-20-2008   #3 (permalink)
Span Key The Money key
VMware SERVER is free and better than that stupid VPC 2007!
"John Barnett MVP" <freelance@xxxxxx> wrote in message
news:OT2o$R1GJHA.4272@xxxxxx
> also don't get USB support on VPC 2007.
> John Barnett MVP
> Associate Expert
> for
> the
> mail/post..
Quote:
>> Hi,
>> 4 G memory and VPC 2007..
>> Kind regards,
>> Tony Thijs
>> Oriolus Publishing
Old 09-20-2008   #4 (permalink)
Richard G. Harper
There isn't much to it - use the wizard in Virtual PC to prepare the new VM
(basically you're just deciding how much drive space, memory, etc. to
dedicate to it and what its name should be) and from there you install the
OS for the new VM the same as you would on a "real" computer.
Richard G. Harper [MVP Shell/User] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
Quote:
> Hi,
> Kind regards,
> Tony Thijs
> Oriolus Publishing
Old 09-20-2008   #5 (permalink)
Vista Ultimate x64
I use VMware workstation on my ultimate machine for XP and Ubuntu (And OSX on occasion) and they work beautifuly. if you have hardware virtualization, vmware workstation and server support that as well and it makes a BIG difference in VM performance as well.
Old 09-20-2008   #6 (permalink)
Vista Ultimate 32-bit
Have you tried reading the built-in documentation of VPC 2007? It is well written, and VERY complete... But also, I pointed a friend of mine who wanted to install VPC 2007 and a guest WinXP OS on his Vista machine to this page, which is detailed and has a lot of screenshots:
Geek to Live: Run Windows XP inside Vista with Virtual PC
Old 09-21-2008   #7 (permalink)
Tony
I have a lot of USB devices; Re: Guide about setting up and mounting a virtual machine
Thanks to all for the advice. I guess the big difference between VMware and
VPC is harware support. I have a network scanner / printer (HP6310) that I
must use and test.
I will be installing Vista and XP Pro on Vista Ultimate and I have a lot uf
USB devices. The software I am testing makes extensive use of USB devices
like a Plantronics USB CS60 headset and the HP 6310, next to a cardreader,
Jabra Bluetooth dongle etc.
Kind regards,
Tony Thijs
"LeeTutor" <guest@xxxxxx-email.com> schreef in bericht
news:7186d3df1b2b82491f9ce4e21604e14a@xxxxxx-gateway.com...
> 'Geek to Live: Run Windows XP inside Vista with Virtual PC'
> (http://lifehacker.com/software/windo...-pc-238071.php)
> LeeTutor
> If this answer has been of help to you, then please add to my Reputation
> by clicking on the middle icon at the top right.
Old 09-21-2008   #8 (permalink)
John Barnett MVP
Re: I have a lot of USB devices; Re: Guide about setting up and mounting a virtual machine
Tony, you are not going to get USB support with VPC 2007.
John Barnett MVP
Associate Expert
mail/post..
newsD913EA2-522A-4FE0-9CF7-5287668867AD@xxxxxx
> and VPC is harware support. I have a network scanner / printer (HP6310)
> that I must use and test.
> uf USB devices. The software I am testing makes extensive use of USB
> devices like a Plantronics USB CS60 headset and the HP 6310, next to a
> cardreader, Jabra Bluetooth dongle etc.
> Kind regards,
> Tony Thijs
>> LeeTutor
Old 09-21-2008   #9 (permalink)
Richard G. Harper
Same answer - if it connects to a USB port, Virtual PC/Virtual Server won't
be able to use the hardware.
news:94A6A11B-4BFE-45B2-AFCA-1AD43A2A99C3@xxxxxx
Quote:
> Thanks John,
> What about USB over Ethernet solutions? Any positiev experience onn that
> side?
> Kind regards,
> Tony Thijs
> Oriolus Publishing
> "John Barnett MVP" <freelance@xxxxxx> schreef in bericht
> news:uWR34L%23GJHA.3504@xxxxxx
>> John Barnett MVP
>> Associate Expert
>> for
>> the
>> mail/post..
>>> Kind regards,
>>> Tony Thijs
>>>> LeeTutor
>>>> Reputation
Old 09-22-2008   #10 (permalink)
John Barnett MVP
You are still going to need USB support on the Virtual Machine; without it
you won't get it to work. Looks like you will need to take a look at VMware
Workstation rather than VPC 2007/VM Server.
John Barnett MVP
Associate Expert
mail/post..
Quote:
> Thanks John,
> side?
> Kind regards,
> Tony Thijs
> Oriolus Publishing
>> John Barnett MVP
>> Associate Expert
>> for
>> the
>> mail/post..
>>> Kind regards,
>>> Tony Thijs
>>>> LeeTutor
>>>> Reputation
Virtual PC 2004 upgrade to 2007 Add an existing virtual machine Virtual PC
Problems with setting up Virtual Machine Virtual PC
Re: WSUS 3.0 SP1 Running as a Virtual Machine in Virtual Server 2005 Virtual Server
Unable to install Virtual Guest Services on virtual machine Virtual Server
RE: Virtual PC could not open the Virtual Machine Network Services driver Virtual PC
