Vista - Problem In Vista ,Svchost.exe Process Pls Help Its Slowing My Pc..
Old 09-21-2008   #1 (permalink)
AhM3D
Hallo..!!
my pc is running verry sloow cuz svchost is using all the process ,
when i opened the taskmgr.exe it listed me like 12 svchosts running , i
have tryed all the antivirus,anti malware, registery repair etc..
programs but nothing helped.
this's a pic to explain :
http://www.image-shed.com/i/guest/e02dca7bdc.jpg
Pls help me cuz i cant play games or run programs well, i aslo
unistalled all p2p programs but nothing too...
AhM3D =]
AhM3D
Old 09-21-2008   #2 (permalink)
Malke
Re: Problem In Vista ,Svchost.exe Process Pls Help Its Slowing My Pc..
AhM3D wrote:
Quote:
> Hallo..!!
Use some of Sysinternals' free tools to determine what each svchost.exe
process is connected with. Process Explorer should show you that:
http://www.microsoft.com/technet/sys...s/default.mspx
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
FAQ - http://www.elephantboycomputers.com/#FAQ
Old 09-21-2008   #3 (permalink)
D. Eth
"AhM3D" <AhM3D.31c00a7@xxxxxx> wrote in message
news:AhM3D.31c00a7@xxxxxx
Quote:
> Hallo..!!
> AhM3D =]
> AhM3D
You can kill Windows Search thru services.msc.
Will free up a little RAM.
How much RAM you got ?
If you don't have 2 GB, its gonna be tough.
Ens causa sui
Fit caedes omnibus locis
Old 09-21-2008   #4 (permalink)
brummyfan
Quote:
> > Hallo..!!
> > AhM3D =]
> > AhM3D
> Ens causa sui
So,anything less than 2GB of RAM is bad, then how did the OEMs pre installed
Vista with Memory less than 2GB and no body informed about this to the
unsuspecting customers. Its a rip off of a high degree.
Old 09-21-2008   #5 (permalink)
AhM3D
my pc ram is 2GB and i tryed to Disable some servies too but its not bad
and i think this is trojan cuz in first there was not 12 svchosts
running..
AhM3D
Old 09-21-2008   #6 (permalink)
D. Eth
"AhM3D" <AhM3D.31ca966@xxxxxx> wrote in message
news:AhM3D.31ca966@xxxxxx
> running..
> AhM3D
I have 11 running.
If you tried the link that Malke provided to Process Explorer...it shows the
processes running in them, will help you determine if they are MS
processes.Also, you can kill some, like print spooler.
Ens causa sui
Old 09-21-2008   #7 (permalink)
Paul Montgumdrop
Re: Problem In Vista ,Svchost.exe Process Pls Help Its Slowing MyPc..
> running..
You can use Process Explorer and go look at what each SVCHost.exe is
hosting. Also, if SVChost.exe is not running out of the Windows\system32
folder, then it's a trojan.
PE is being explained in the link.
<http://www.windowsecurity.com/articles/Hidden_Backdoors_Trojan_Horses_and_Rootkit_Tools_in_a_Windows_Environment.html>
<http://technet.microsoft.com/en-us/sysinternals/default.aspx>
You can go to a line in the upper or lower pane, right-click it and go
to Properties.
Svchost.exe Problem.... Vista performance & maintenance
what process is svchost.exe associated with Vista performance & maintenance
Startup problem blank screen SVCHOST properties Vista performance & maintenance
Startup slowing problem with Vista h.e. Vista General
svchost process using 86% of CPU Vista General
